Help, problem with rpm's
i was driving normal today on the highway coming off a ramp, then i decided to punch it, watched the rpm's climb 2....3....4...then from 4k it JUMPS straight to 5 (it didnt climb constantly like it normally does). then later on i was racing that night and it does it again, but this time it jumped from like 7k past redline. what is wrong??
did it feel like gears slipped? mine has done it before, but only when hydroplaning(flooded on one side of road, not on other, going fast on freeway), not gear slipping
Are you sayin that the RPM needle quickly jumps to 7g's then back down all of a sudden even though the engine is revving? If it does then it could be a problem in the electrical system. If not then it may be your engine or tranny goin south after all that abuse.
When the tach jumps, if its just bogus electrical trouble, you won't hear the engine actually rev. If the engine is actually revving like that, it sure sounds like a slipping clutch.
