Help PLEASE!!!
Old Sep 16, 2001 | 02:10 PM
kilabeez's Avatar
New User
Default Help PLEASE!!!
ok, i'm pretty sure both my front axles are shot because it clicks when i turn both ways. Even though I just did the drivers side a few months ago. Anyway, I THOUGHT my passenger rear wheel bearing was bad because it made a humming noise on the highway and when I cut the wheel to the RIGHT. So I replaced the hub and bearing but the buzzing is still there!!!
What else could it be? I cant really tell where it's coming from but it's only when I cut the wheel to the right or I'm driving fast. Maybe my exhaust is rubbing? Maybe it's a front bearing???
Old Sep 17, 2001 | 07:53 AM
kilabeez's Avatar
New User
Default Re: Help PLEASE!!! (kilabeez)
Can someone tell me how the HELL to take the passenger axle off??? I forget how, and now I'm stuck. I removed the HUGE nut in the center of the wheel on the end of the axle, and took off the caliper and even the rotor to get a better look. Then I took off the locking pin and nut on the very bottom of the control arm. I also removed the long steel pin from the fork. I think I need to separate the ball joint right above where I removed the locking pin and bolt but I cant get it to budge with a ball joint remover. Am I just not hitting it hard enough? I even jacked up the hub a little so maybe the lower arm would fall down or at least fall when I shoved the ball joint remover in there. BUT NOOOOOOOO not happening. Someone please tell me what the hell i'm doing wrong.
Old Sep 17, 2001 | 11:22 AM
5 Liter Eater's Avatar
You really have to smack the crap out of the ball joint to get it to come off if you're using a fork seperator like I have. I broke the tip off of my hammer whacking on it. You'll probably rip a boot too.
follie gatts
Jan 28, 2009 12:06 PM
HOODLOVER
Oct 26, 2008 07:24 AM
spets
Suspension & Brakes
Apr 5, 2008 05:31 PM
truevietluv636
Sep 8, 2007 03:00 PM
y49crxsi
Jul 14, 2004 10:51 AM
