Help no signal or hazard lights work!
i've already checked the fuses, any other ideas? they don't work nor does the signals indicators on the dash work either.
Re: Help no signal or hazard lights work! (Vap133)
Try the blinker relay. It should be silver in color and the shape of a 19mm socket. I dont know where exactly it is, but it should be around the fuse box.
Re: Help no signal or hazard lights work! (speedevo)
If not the relay, try swapping the button for your hazards with a fellow Teg owner. Take a screwdriver and pry it out from the bottom. Be careful not to break the clips on the side, it should be a little tight but come right out. I noticed with mine out the blinkers don't work so something could be wrong in there.
