HELP!!! MY WINDOW IS STUCK DOWN!!!
Old May 25, 2007 | 07:20 AM
Bro. Darkness's Avatar
Default HELP!!! MY WINDOW IS STUCK DOWN!!!
I just bought a 92 LS and everything worked fine when i test drove it and after i bought it (yesterday) and cruised until i drove to work and tried to put my driver side window back up. it rolled halfway up and stopped. i worked all night and when i cranked it up in the morning i just pressed the switch up and kinda helped the window up a lil bit and that worked. I ran some errands with the windows down today and now i cant even pull the window up. Im new to all of this so i have no idea where to start troubleshooting. Any advice will help.
Old May 25, 2007 | 07:45 AM
dorifto_83's Avatar
it probably fell out of track, take off the door panel and make sure the glass is in the track. Also try lubing the weather stripping if it's getting the glass caught on it. good luck.
Old May 25, 2007 | 07:52 AM
Default Re: (dorifto_83)
actually i just did the pull-up trick again and i noticed theres some sticky **** down on the bottom part of the glass on the inside so i guess im gonna try and clean that up and roll it down again and see what happens when i roll it back up.
Old May 25, 2007 | 08:19 AM
Default Re: (Bro. Darkness)
i wiped the sticky **** off with alcohol but the same result....guess ill have to pull the door panel.
Old May 25, 2007 | 10:46 AM
jdancer987's Avatar
a friend of mine just had this happen on a prelude and it was the switch before the motor and it's getting replaced today
Old May 25, 2007 | 05:22 PM
deeznuts6009's Avatar
Default Re: (jdancer987)
my window was getting stuck for a while, i would have to smack the door a few times to get it working againe. i thought it was the switch board on the door. it finally got stuck two days ago. when i checked the motor, it keeped running by itself. and stop im gonna try n get a motor and try see if that work. and the motor would get soo freaking hot. looked like the motor was pretty messed up on the inside too. but good luck.
Old May 27, 2007 | 05:52 PM
well it will end up being the switch, just in case you havent gotten to it yet, i just fixed my window yesterday. got it at a junkyard. works like new.
Old May 27, 2007 | 08:00 PM
Blahblah718293's Avatar
Default Re: (deeznuts6009)
i think my motor is getting old.. when i roll up my windows they go up just fine but they sound like theyre just struggling so much. how much would it be for a pair of new motors?
Old May 30, 2007 | 12:21 PM
stnguyen82's Avatar
Default Re: (Blahblah718293)
yeah i say take off the panels and test the motors sounds like bad motors to me. junk yard or even ebay sells them for a decent price
Old May 30, 2007 | 03:27 PM
TheKid1488's Avatar
This happened to me last year. The problem with mine was that the motor was old and overheating so you may just need to replace your motor.
Old May 30, 2007 | 04:21 PM
apok's Avatar
Default Re: (TheKid1488)
Mine driver's side is doing the same thing..probably from being used so much more than passenger. I'm looking into replacing the motor since it seems to be overheating/not working in the next few weekends when I have some spare time/money.
laoboisosilly
Jun 3, 2009 02:14 PM
Agent Zero
Aug 13, 2004 01:53 PM
Matt B
Jan 14, 2004 08:50 AM
EX-T
Nov 27, 2003 07:26 AM
io_burn
Oct 14, 2001 08:27 PM
