help me
Old Mar 29, 2005 | 01:07 PM
xhimurakenshinx's Avatar
Default Help Me, Engine Wont Start Anymore After Compression Test
ok here's the problem, me and my friend were fixing my gf's car the other day and then we started by doinga compression test. so we pull out a spark plug on a piston and we run the test. and then we put the plug back in and then we do the same for the rest. right after we do the compression test though, the car wont start. it'll crank but it wont start. anyone know the problem?? help -_-
Modified by xhimurakenshinx at 7:48 PM 3/29/2005
Old Mar 29, 2005 | 01:42 PM
SiR AuToBoT's Avatar
Default Re: help me (xhimurakenshinx)
it could be a bad fuel pump relay
Old Mar 29, 2005 | 04:00 PM
Swift_asian's Avatar
1.did you put fuse back for the injectors?(asume u took the fuse out when u did the compression test)
2.plug wires did u put them back in the right place?
3.make sure your plugs arnt damaged when u took em out
good luck
Old Mar 29, 2005 | 06:35 PM
Default Re: help me (Swift_asian)
yea, the thing is that for the first time we did the test, we forgot to take the fuel injector fuse out for 1 piston. but yea, we put them back after. still doesnt start -_-
Old Mar 29, 2005 | 08:12 PM
help
topshotta08
Jan 28, 2009 01:07 PM
Bngo731
Jun 5, 2006 02:42 PM
xhimurakenshinx
Apr 2, 2005 06:36 PM
ownedbyvtec
Oct 4, 2003 09:56 PM
J-g-D-s-M-r
Sep 29, 2003 02:32 AM
