Help with Idle problems
Old Sep 29, 2003 | 07:04 AM
Caliman's Avatar
Default Help with Idle problems
98 Integra GSR 50k miles on it.
Well I have been having some idle problems. I thought I would try to fix them myself and I have had no success. First I did the general maintanence and the car seemed to run fine but when I come to a stop the idle bogs down to like 100rpms and then goes up to about 400-500. This seems to be a little low.
So last night I thought what the heck I should pull the IAC valve off and clean it. My friend told me to use some intake cleaner and spray it really good. After letting it dry and re-installing back in the TB the car started up as usual. Now sometimes my car dies when I slow down to a stop. Not every time. I did drive it this morning and it didnt die. Any ideas for this problem? I'm probably going to just pay someone to tell me whats wrong, but if I can fix it I would definetly try that first.
Old Sep 29, 2003 | 07:36 AM
Calavera's Avatar
Default Re: Help with Idle problems (Caliman)
are you sure it drops all the way to 100rpm? car should have stalled if it did. sorry not really any help. free bump.
Old Sep 29, 2003 | 08:20 AM
Caliman's Avatar
Default Re: Help with Idle problems (Calavera)
well the RPM guage drops to the bold line at 0 almost. I'm guestimating 100rpms becuase if it was 0 it would be off right? But the RPM does drop to almost 100rpms when I slow down then slowly goes up to like 500.
Old Sep 29, 2003 | 05:46 PM
stumpyf4's Avatar
Have you cleaned your throttle body and the back of the throttle plate? Check your TPS (throttle position sensor voltage under full close and full open). Make sure the voltage steadily rises and falls with no big jumps.
Old Sep 29, 2003 | 06:22 PM
greekspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">are you sure it drops all the way to 100rpm? car should have stalled if it did. sorry not really any help. free bump. </TD></TR></TABLE>
uhh its impossible for the car to idle at 100rpm it would sooner stall......... as far as i know the gauge starts at 500.....first thick white line on tach is 500 rpm..
Old Sep 29, 2003 | 11:05 PM
integrasi's Avatar
Default Re: Help with Idle problems (greekspeed)
it seems like your car is running rich during dile, have u installed toda cams? or bigger cams, that could cuz idle problem, anyhow, u need ecu management system or some way to lean out your fuel.
Old Sep 29, 2003 | 11:20 PM
HONDADNA's Avatar
Check your base idle it should be 800+/- 50 rpm with service check connector shorted. Also check you ignition timing that is correct.
Old Sep 30, 2003 | 07:25 AM
NeoGSR's Avatar
Default Re: Help with Idle problems (HONDADNA)
how's your gas mileage? might be an 02 sensor....but your not throwing any codes......hmmm......i'd check the TPS like someone else said.....
Rage97
Aug 19, 2013 12:11 PM
bb4 jdm lude
Mar 12, 2008 09:25 AM
hybridracer504
12
Feb 8, 2005 05:25 PM
project_one42
Feb 2, 2005 06:30 PM
