HELP : Idle Problem
Old May 3, 2005 | 03:36 PM
j87w's Avatar
Default HELP : Idle Problem
I just swapped a 95 JDM GSR into my 95 Teg LS. Im listing these mods because they might help figure out the problem. It has a Skunk2 Pro Series IM, CTR Intake Cam, and then IHE. It runs great, no check engine light. It has 1 problem though, it idles back and forth from 1000 to 2200. I checked and all my hoses are hooked up to the IM, when I first start it though it idles just fine at like 2200. Then it just starts going back and forth when its warm. I cleaned the IACV out today and it seemed a little better but didnt fix it. Anyone got any ideas?
Old May 3, 2005 | 04:24 PM
rustyhatch's Avatar
Default Re: HELP : Idle Problem (j87w)
clean the iacv using berryman's B12 chemtool. put it in a plastic bag and let it soak overnight at least. it should free it up.
Old May 3, 2005 | 09:26 PM
j87w's Avatar
Default Re: HELP : Idle Problem (rustyhatch)
Well, I pulled the clip off of the IACV and it idled steady at like 1400 at operating temp. I have not tried to clean the IACV again. It doesnt throw a code until I pulled the clip for the IACV off. Then if I plug the IACV in it idles between 1000 - 2200 again. Anyone have any ideas?
Old May 4, 2005 | 06:20 PM
j87w's Avatar
Anyone else?
Old May 4, 2005 | 06:24 PM
boosted_teg's Avatar
i had a problem with my cold start valve or something its located under the throttle body. i opened it and there is this white circle with a t. it was pushed out to far i turned it to tighten it and boom my problem was gone. Sorry for the non professional explaintion i usually am not explaining but just fixing
Old May 4, 2005 | 09:13 PM
j87w's Avatar
Default Re: (boosted_teg)
Are you talking about the FITV? Its right under the throttle body with like 3, 10mm bolts. I havent tried it but theres a screw that comes loose and you have to tighten it up right? Is that what your talking about?
Old May 4, 2005 | 09:56 PM
cheeks97R's Avatar
I kinda had the same problem when I put my skunk2 IM. I tried 2 things, 1st I loosned/tightened a screw on the throttle body. I messed with it till it sounded a lil better and Idled steady. When it started idleing funny agian I took the idle control valve off and stretched the spring till it looked normal and put it back together agian and its worked fine. Every once in a while the control valve messes up agian but isntead of buying it Im just do the same steps, good luck.
Old May 4, 2005 | 10:08 PM
ya that was what i was talking about good luck man
silverlude80
Aug 2, 2011 07:43 PM
veearr6
Mar 12, 2010 01:12 PM
homeskillet
Jan 13, 2005 05:04 PM
Black 2K
Jul 23, 2003 11:52 PM
