Help ID these engine harnesses please
These have been in my garage for awhile. I forget which is which. I also want to know how to depin this green connector. It fell off one of the harnesses. I think the 5th plug on the fuel injector plugs is a clue but I’m not sure what either one is from I think one is 97 integra gsr and one is 99 integra ls. Any help would be awesome thanks.
This fell off one of them
Two wire plug how do I get this apart to repin?
Harness 1
Harness 1 with 4 injector plugs
Harness 2
Harness 2 with this plug ?
Harness 1
Harness 2
Re: Help ID these engine harnesses please
'Fifth' plug on the injector leg of the loom looks to be the IAT sensor. The green 2 pin connector is usually on the vtec solenoid, from what I've seen. I can see it in your 'Harness 1' photo. Hard to tell for sure, without the wire colors listed.
If you pop the contact lock (white piece) out of the front of the connector, you can use a very small screwdriver or preferably a depin tool to release the contact and slide it out the back. Most likely you'll just want to get a new connector from Corsa-Technic and crimp on a freshie.
1nsoman1ac
10
09-22-2009 01:08 PM
