HELP.... Front Hub problems
Old 03-14-2006, 06:42 PM
cheaphonda's Avatar
Default HELP.... Front Hub problems
i have a 1994 integra ls. I am currently trying to remove my front passenger hub in order to replace my lug studs since they are spinning. I already removed the brake caliper and the rotor...I cant figure out how to remove the actual hub though.... the integra shop manual is not very clear...
anything will help guys
help asap please.
matt
Old 03-14-2006, 06:44 PM
cheaphonda's Avatar
Default Re: HELP.... Front Hub problems (NeverSummer155)
anything???? I am really desperate
Old 03-14-2006, 06:59 PM
cheaphonda's Avatar
where are you honda-tech when i need you most
Old 03-14-2006, 07:38 PM
scotts93ls's Avatar
if you take the backing plate off you sould be able to punch the studs out
Old 03-14-2006, 08:52 PM
ITR#132's Avatar
you have to press the hub out of the wheel bearing
this will help:
https://honda-tech.com/zerothread?id=720159
Modified by ITR#132 at 10:34 PM 3/14/2006
Old 03-15-2006, 01:52 AM
SiR Adam's Avatar
Alexpbnj
05-01-2011 11:10 PM
simonEp3
09-03-2008 04:49 PM
NeWsCr
12-13-2006 06:43 AM
classciv
08-27-2004 06:24 PM
slowassR
04-30-2003 01:44 PM
Quick Reply: HELP.... Front Hub problems
