HELP.... Front Hub problems
Old Mar 14, 2006 | 06:42 PM
cheaphonda's Avatar
Default HELP.... Front Hub problems
i have a 1994 integra ls. I am currently trying to remove my front passenger hub in order to replace my lug studs since they are spinning. I already removed the brake caliper and the rotor...I cant figure out how to remove the actual hub though.... the integra shop manual is not very clear...
anything will help guys
help asap please.
matt
Old Mar 14, 2006 | 06:44 PM
cheaphonda's Avatar
Default Re: HELP.... Front Hub problems (NeverSummer155)
anything???? I am really desperate
Old Mar 14, 2006 | 06:59 PM
cheaphonda's Avatar
where are you honda-tech when i need you most
Old Mar 14, 2006 | 07:38 PM
scotts93ls's Avatar
if you take the backing plate off you sould be able to punch the studs out
Old Mar 14, 2006 | 08:52 PM
ITR#132's Avatar
you have to press the hub out of the wheel bearing
this will help:
https://honda-tech.com/zerothread?id=720159
Modified by ITR#132 at 10:34 PM 3/14/2006
Old Mar 15, 2006 | 01:52 AM
SiR Adam's Avatar
Alexpbnj
May 1, 2011 11:10 PM
simonEp3
Sep 3, 2008 04:49 PM
NeWsCr
Dec 13, 2006 06:43 AM
classciv
Aug 27, 2004 06:24 PM
slowassR
Apr 30, 2003 01:44 PM
