Help Da9
Old Jan 30, 2013 | 07:41 AM
LoveMyteggy's Avatar
Icon2 Help Da9
Hii I'm having a bit of a problem my 91 integra started over heating on me but not to the max my temp meter goes up about a pinky but once I pick up speed it goes back down?? wanna make sure what it is before I go out there and do stuff to it if any one could help or has had this problem. Would really appreciate the help.
Old Jan 30, 2013 | 09:36 AM
DirtyDA9's Avatar
Default Re: Help Da9
Top it off.
Old Jan 30, 2013 | 09:44 AM
JuicedUpRice's Avatar
Cold start the car and take off the radiator cap.while its running pour your antifreeze in and let it sift until its full,then close it back up..
Old Jan 30, 2013 | 12:18 PM
Solster's Avatar
I'll try and see if i under stand you correctly first.
ok so you start the car cold and let it idel till it warm to about 1/4 temp guage or as you put it "it goes up a pinky" ( i assume the width of your pinky finger fron the C) then when you take off and get up to speed it drops back to to the C.
if the above is correct then i would look into a NEW thermostat as yours is stuck open or is missing.
if you mean to say the is reaches normal running temp of 1/2 temp guage and when you stop it goes up a pinkys width then drop back down when you get up to speed.
i would say you are low on coolant and need to top off the system. if you are low on coolant the question is WHY??
i would look for leaks and check the oil if the oil looks like a chaco milkshake it's time for a headgasket.
Old Jan 30, 2013 | 05:39 PM
Thanks every one and B20forlife the second one you mention is the correct one it reaches half way and once the car is stop the temp starts rising not much tho once I put it into gear and head of the temp starts cooling down to below half. thanks for the help really appreciate it. any clue how much the head gasket replacement would go for if it is that?
Old Jan 30, 2013 | 06:23 PM
Also is there any good way I can test if its a blown head gasket?
Old Jan 31, 2013 | 12:44 AM
ahtublao's Avatar
i dont think theres a way but if you check your oil and coolant and it doesn't look like chocolate milk then its fine. most likely your issue is a thermostat problem or you need to top it off
Old Jan 31, 2013 | 02:38 AM
Solster's Avatar
Cooling system pressure is a cheap test for HG leak.
Compleatly cold first start up of the day.
Pop the hood and make sure the radiatior is full of fluid and replace the cap.
Now squeeze the upper rad hose and it should be fairly ez to squeeze.
now start the car and as soon as it starts get out and squeeze the hose again.
if it's firm and hard to squeeze but still cold your HG is Blowen.
Old Jan 31, 2013 | 06:43 AM
Alright bro thanks Really appreciate the help!
Old Jan 31, 2013 | 11:46 AM
Good news it has nothing to do with my head gaskets ^.^ happy AF thanks for the help guys! most likely its my thermostat or water pump!
jdm36
29
Dec 17, 2010 06:59 PM
90crxdriver
Jul 4, 2007 10:45 AM
CrisEK
Sep 30, 2005 04:27 PM
94civicDX
Mar 27, 2005 01:25 PM
