Help with CEL codes.
Old Apr 5, 2011 | 03:52 PM
SiLEnT_ST's Avatar
Default Help with CEL codes.
Car: 1996 Acura Gsr 4 door
So I was driving to the DMV today to go pay for my renewal tags and I notice my check engine light on. I didnt have a scanner on me so I used a wire to connect the 2 wires under the glove box.
This is what it threw:
http://www.youtube.com/watch?v=-2b2CaxCQTk
My question is, I followed this thread here (https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/) but not sure if Im doing something wrong or if the thread is mistaken something.
The thread said that long flashes are tens digit and short flashes are ones digit.
So that means the code that my CEL threw would be 92? But there is no code 92 in the thread?!
Or is it 9 long flashes for code #9 and 2 short flashes for code #2?
Srry, im lost.
Old Apr 5, 2011 | 05:19 PM
fonkernuckle's Avatar
Default Re: Help with CEL codes.
IMO it appears that you have a code 90 Evap emission Control Leak detected in fuel take area(did you hear at least 3 clicks when you put your gas cap on--this is just a guess) and a code 2 =oxygen sensor #2
Old Apr 5, 2011 | 05:34 PM
SiLEnT_ST's Avatar
Hmm, i'll check that out about the gas cap. And the o2 sensor, do you think its the o2 sensor or the cat? I just bought a brand new cat somewhere in January, but my car is dropped and I mostly have a few passengers and always hitting the cat on bumps becuz the stupid shop welded it on the piping and its looks like its hanging.
Old Apr 7, 2011 | 04:58 PM
SiLEnT_ST's Avatar
I checked my gas cap but there was no rip or anything on the rubber, everything looks clean and good. Any ideas what it could be?
Old Apr 7, 2011 | 05:58 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You sure you can pull the codes that way? Your car is OBD2 and should require a scanner.
Old Apr 7, 2011 | 06:01 PM
SiLEnT_ST's Avatar
Hmm, Im not sure. Never thought of that. I'll go to autozone or something and ask them to scan it to double check.
But one thing too is that wen i open the gas cap it doesnt have that air release sound, like its not air tight but i closed it all the way already.
Old Apr 7, 2011 | 06:50 PM
mouab18c1's Avatar
It works. I used this method when I was still running my obd2a ecu.
Old Apr 8, 2011 | 11:21 AM
SiLEnT_ST's Avatar
Alright kool, im running obd2a ecu atm too.
karrar55
Aug 29, 2009 04:52 AM
GsrVtec
Oct 19, 2006 07:33 AM
jArceo
Oct 14, 2003 05:02 PM
AamirCWITR
Jun 25, 2003 01:47 PM
