help!!! broken bolt...replacable?
Old May 22, 2006 | 10:11 AM
teg your it's Avatar
Default help!!! broken bolt...replacable?
hey guys
i just replaced my valve cover and as i was tightening one of the bolts, it broked. i dont' know the exact name for it. but is this thing replacable or i need a new motor just to get this thing back because i seems like it's connected to the motor.
so i really need some big help. i dont' want oil outside again. i took out the valve cover so i can replace the cam seal to prevent oil leak. and now this...
thx!
Old May 22, 2006 | 10:16 AM
CJ_2Dr's Avatar
Default Re: help!!! broken bolt...replacable? (AzNsX_84)
couple days ago i was doing the same thing and i lost one of the gramets that sit below the nut and i drove it around for about 3 days until i found it and put it on but no oil came out of the hole, i thought it would have but it did not. but i am not sure if that is fixable. i will let someone else say something but i think u will be safe to drive like that for a couple days, prob not a long time tho good luck
Old May 22, 2006 | 10:42 AM
YEABOY's Avatar
Default Re: help!!! broken bolt...replacable? (redDCcoupe)
It is replacible. all you do is take off the valve cover and remove that stud with a 10 mill deep soket. and replace it with anotehr just like it. but no broken though
Old May 22, 2006 | 12:35 PM
Default Re: help!!! broken bolt...replacable? (Integ4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integ4Life &raquo;</TD></TR><TR><TD CLASS="quote">It is replacible. all you do is take off the valve cover and remove that stud with a 10 mill deep soket. and replace it with anotehr just like it. but no broken though</TD></TR></TABLE>
damnit. i have to take out the valve cover again. i just replaced the valve cover gasket and cam seal. i dotn' need to replace the valve cover gasket again do it?
Old May 22, 2006 | 12:36 PM
gsr dood's Avatar
yea worst comes to worst all its connected to is your cam cap so its fine. just watch for oil leaking....u should be fine
Old May 22, 2006 | 12:43 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: help!!! broken bolt...replacable? (gsr dood)
Dude, you're totally screwed.
You're gonna have to sell that motor now....I'll give you $200.
Old May 22, 2006 | 12:49 PM
DC2 Mang's Avatar
you can re-use the vavlecover gasket, just wipe it clean of oil and you will be fine
Old May 22, 2006 | 07:59 PM
Default Re: help!!! broken bolt...replacable? (carma_626)
thanks guys...ill do that asap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 &raquo;</TD></TR><TR><TD CLASS="quote">Dude, you're totally screwed.
You're gonna have to sell that motor now....I'll give you $200. </TD></TR></TABLE>
lmao......if you were the first to post. you would scare the **** out of me
civic=goodgasmileage
Honda Civic (2001 - 2005)
May 25, 2010 01:31 PM
mikej94civex
Mar 2, 2010 03:57 PM
00ekcoupe
Sep 4, 2005 12:15 PM
inane
Mar 5, 2005 09:50 PM
TeamTooQuick
May 21, 2002 05:23 PM
