Please help...
Old May 18, 2002 | 02:21 PM
TeamTooQuick's Avatar
Default Please help...
I stripped the paint off my valve cover and put it back on, i drove around and noticed it was leaking a little beat out one corner, so i tried 2 tighten it a little and crack it breaks, will i leak a lot of oil?? can i drive on it? TIA
Old May 18, 2002 | 02:30 PM
ragejed's Avatar
Default Re: Please help... (TeamTooQuick)
cracked the valve cover? god no!, dont drive it!
its like driving around with a crack in your head, jeez, sorry dude
just get a jdm valve cover
Old May 18, 2002 | 02:33 PM
Default Re: Please help... (ragejed)
im sorry, i ment the valve cover stud...
Old May 18, 2002 | 04:11 PM
vteg's Avatar
New User
If your others a tightened ok you can drive it. You will lose oil though. I drove with a broken stud my valve cover for like 20k miles I did not correct it until my 45k valve adjustment.
Old May 18, 2002 | 04:19 PM
SIK IN DA HED's Avatar
New User
Default Re: Please help... (vteg)
it will be ok. just try to get a new stud asap. its only like $5 at the dealer. easily to replace too. get some honda bond while youre there so you can seal it better so the valve cover doesnt leak.
Old May 18, 2002 | 04:26 PM
Default Re: Please help... (dlplayboy)
how many pounds of torque should i tighten it???
Old May 18, 2002 | 07:58 PM
Audi A4's Avatar
dont u remeber waht tom said man. gotta get taht honda bond. lemme know if i can help. but dont sweat it man nothing major
Old May 19, 2002 | 06:40 AM
Default Re: Please help... (DRAG lll INTEGRA)
oils commin out a good bit around the stud, like the stud still sticks through but it comes around it, and i dunno what i can use 2 cover around the stud so it stops...
Old May 19, 2002 | 06:44 AM
ragejed's Avatar
gasket maker?
Old May 19, 2002 | 10:56 AM
whats gasket maker?? but wouldnt i just have 2 buy a new stud and just take off the valve cover and take out the old one and put the new one in, theirs a little bit of the stud still sticken out of the valve cover...
[Modified by TeamTooQuick, 7:58 PM 5/19/2002]
Old May 19, 2002 | 12:36 PM
Audi A4's Avatar
yeah just go to acura tomm and get a stud like 8 dollars. then replace it, remeber dont over torque this one and get some damn hondabond.
by the way how did the valve cover turn out, and is ur valve cover gasket in good condition, cause if it isnt then u need to get a new one of those to
Old May 19, 2002 | 05:12 PM
i put hondabond on it in the first place, gasket is in good condition...
Old May 19, 2002 | 06:15 PM
Audi A4's Avatar
well then less muscel
Old May 21, 2002 | 06:07 AM
got a new stud and fixed it, all went well this time...
Old May 21, 2002 | 06:32 AM
Audi A4's Avatar
yeah i sasw u yesterday i was at the circle k in jonesboro right on corner of 138. i had just left from acura. had to get cap and rotor. howsthe valve cover look?
Old May 21, 2002 | 06:39 AM
vavle cover looks real good, i like it...
Old May 21, 2002 | 09:04 AM
Audi A4's Avatar
hmm is it shiny
Old May 21, 2002 | 05:23 PM
nope, but what grit sand paper should i use 2 sand the valve cover so i can polish it???
boosted91crx
Mar 31, 2009 11:19 AM
webbs2jzgte
Mar 10, 2009 09:32 PM
racereaper7
Honda Civic (2006 - 2015)
Apr 12, 2008 06:19 PM
Si_chRis
18
Jul 5, 2006 05:25 PM
Dopamine_44
Nov 13, 2001 01:27 PM
