Help with a basic(hopefully!) problem with 1995 RS
Old May 28, 2003 | 10:53 PM
95hydraulicrs's Avatar
Default Help with a basic(hopefully!) problem with 1995 RS
Well, I just got a new clutch(and axles) installed (OEM) and have broken it in fairly nicely...
That was about two weeks ago, and just a few nights ago i was makin' a U-turn(left) and as the wheel was cranked over I heard a weird metallic sounding pop, and just then a peice of metal bouncing away (ting...ting...ting...).
This was about 50 feet from where i parked, and as i rolled down to a stop the car was making a horrid grinding (metal on metal), and the noise stopped about five feet from where i parked for the night.
In the morning I pulled the car into the garage(no weird noises) and took the wheels off. EVERYTHING looks good... axles, brakes, tie-rods,bushings, suspension etc. After trying to snug everything to spec with a torquer, and everything was good... I went for a test drive.
The car seems the same, braking is fine, sharp turns and all... but during acceleration (in gear, gas pressed... but not between shifts) there is a weird solid squeek (not to loud, but definetly noticable outside the car) up to about 20 MPH.
I am fairly tech savvy with hondas, but I am at my last guess...
Any help or input would be greatly appreciated!!!
(Oh yaeh, I used to be on this board as "95lsramair", but i forgot the password and had no secret question... So im not a total newbie)
Thanks alot.
Old May 29, 2003 | 05:09 AM
JimBlake's Avatar
Default Re: Help with a basic(hopefully!) problem with 1995 RS (95hydraulicrs)
So you didn't go chasing that part that went bouncing away?? Knowing what that was would have been a real useful piece of information.
If you had forgotton something like a cotter pin or some kind of clip, left it to get stuck in your brakes; it should have fallen out a while ago. But that's what it sounds like. Something caught between the brake rotor & the splash shield making a grinding noise.
I guess I'd inspect everything again. Band clamp from a CV joint boot?
Old May 29, 2003 | 09:30 PM
Default Re: Help with a basic(hopefully!) problem with 1995 RS (JimBlake)
I tried to look for the part immediately but it was late and pitch black, the part sounded very small.
All 8 cv clamps are new and intact, as well as all other things that i can see...
The noise is progressivly getting louder... and now it does it as i am slowing from 20-0mph in or out of gear, but not between shifts while accelerating... only in gear.
I guess im going to take it to where i got the clutch done (kind of a friend of a friend at my local Midas) and see if they will look at it for free.
Please dont flame me for the Midas either
Old May 30, 2003 | 04:34 AM
JimBlake's Avatar
How about any of those little clips & shims that go in the brakes?
Old May 30, 2003 | 09:56 AM
cletus's Avatar
does the noise change with engine speed???? or does it stay teh same no matter what the engine is doing?
Old Jun 6, 2003 | 10:17 AM
Default Re: Help with a basic(hopefully!) problem with 1995 RS (cletus)
no change in noise with rpm... now it seems to do it when i am coasting with the clutch in at speeds under 20mph... all break pad shims seem intact... ussually doesnt happen during my first 5-10min of driving... kinda like it needs to warm up?
darkwater_ghost
Transmission & Drivetrain
Jan 3, 2013 10:52 AM
nextproject97
Mar 10, 2010 02:21 PM
meangreenEG
45
Jul 6, 2007 08:16 AM
dubzz24
10
Apr 3, 2005 05:06 PM
whteteg8901
Nov 29, 2004 10:37 PM
