Help! 92 Integra wont run.
When you start it, it'll idle fine. If you give it gas it will bog down and die. If you barely give it gas it will rev up then sputter and die. Or if you let it idle for longer than a minute it'll die on its own. Any ideas?
Re: Help! 92 Integra wont run. (AudioXtremes)
id change the fuel filter see if that makes a difference or the pump is going out..but i sounds like its in you r fuel system..
Jammin8519
03-13-2013 11:24 AM
racingrex
11-06-2003 04:46 PM
