Help!
Old Aug 1, 2001 | 02:26 PM
vtekpwr's Avatar
New User
Default Help!
I have a 95 GSR and I need to perform the 60000 mile maintenance on it. I'm really reluctant to take it to the dealer because it's going to cost $700. Can this maintenance be done at a non-acura car shop/garage or whatever, or should i just take it to the dealer?
Old Aug 1, 2001 | 03:34 PM
Quikness's Avatar
New User
Default Re: Help! (vtekpwr)
I say screw the dealership and take it to qualified shop who specializes in hondas and acuras. Of course, if you can do it yourself then that's the way to go.
All you pretty much need to do is as follows:
-Acura Shop Manual ($65+ from Helm I think)
-replace spark plugs
-valve adjustment (recommend having the tool. it's not necessary but extremely helpful)
-oil and filter change
-transmission fluid drain and refill
-coolant flush and refill (or just drain and fill)
-replace distributor cap and rotor (can inspect and see if there's too much corrosion)
-check and replace air filter (if K&N, check and clean if necessary)
Everything else is check this, check that. Just don't take it to a shop who claims to be able to work on ALL types of import cars. Try finding one that specializes in Hondas and Acuras. If all else fails, take it to the dealership.
Old Aug 1, 2001 | 06:03 PM
Wormaker's Avatar
New User
$700 bucks..ouch..I better start saving now..lol already have 11,000 miles on 01 integra.
KrazyDawg
Mar 18, 2008 04:39 PM
vietkangta
Jul 28, 2007 12:43 AM
Moshimoto racing
Dec 28, 2005 09:30 PM
AznJohn33
May 14, 2004 11:12 AM
FK00GSR
May 29, 2003 07:28 AM
