help!!!!!!!
Old Feb 2, 2013 | 01:58 PM
jdmacuraITR's Avatar
Default help!!!!!!!
i don't what wrong with my ls Acura we replace the distributor ,map senor , throttler position senor,and we still get no spark to the engine and the we can hear the fuel pump anyone got any idea
Old Feb 2, 2013 | 02:25 PM
mr_munro's Avatar
Default Re: help!!!!!!!
main relay ?
Old Feb 2, 2013 | 02:41 PM
Originally Posted by mr_munro
main relay ?
the main relay is still good
Old Feb 4, 2013 | 06:20 AM
SolScifen's Avatar
Have you checked to see there's no spark? And that the fuel is getting into the cylinders?
Check engine light throwing codes?
Old Feb 4, 2013 | 06:54 AM
oakteg21's Avatar
Check your grounds check your wiring is correct
Old Feb 4, 2013 | 03:13 PM
SpoonyDC5's Avatar
Ground is my guess
Old Feb 4, 2013 | 04:44 PM
JuicedUpRice's Avatar
check for 12v at the blk/ylw wire coming off the distributor.if you have 12v,youre looking at dizzy internals or anything from the dizzy to the plugs.
if no 12v,youre looking at main relay,ignition switch,or in rare cases the ecu or wiring problems..
Old Feb 4, 2013 | 05:37 PM
beecee18's Avatar
DrewUSARMY
11
Apr 6, 2011 11:51 PM
chazfehn
15
Oct 12, 2008 08:36 PM
89pre2.0si
Jun 7, 2008 11:36 AM
waterblast02
Mar 1, 2007 11:27 AM
3M TA3
Sep 2, 2006 09:22 PM
