heating problem
Old Apr 26, 2005 | 06:19 AM
Honteggie's Avatar
Default heating problem
The search server is down for some reason so I have to post(although I did search other sites). My car doesn't want to warm up. If it idles, it will warm up to normal temp but it never overheats. But when I drive the temp will go all the way down to the 'c' and the heater output ends up just warm, not like when at idle where it is actually hot. Now if i stop at like a light or something, the car will warm back up, not fast but steady. Whats up with this? Some tell me that since it isn't overheating then be happy but I don't like it as a car has to be a certain temperature to operate proberly. Thanks.
Old Apr 26, 2005 | 06:28 AM
StrikerX's Avatar
Default Re: heating problem (wanahonda)
Thermostat stuck open.
Old Apr 26, 2005 | 06:34 AM
Honteggie's Avatar
Thats actually what I was thinking but it didn't make sense why it would actually heat up when idleing and hold the temp steady?
Old Apr 26, 2005 | 06:41 AM
BolivianDc2's Avatar
Default Re: (wanahonda)
I would check the thermostat like the guy said
Old Apr 26, 2005 | 06:51 AM
Honteggie's Avatar
yeah, I will. What would 10 bucks hurt, right? Hell I could use a new one anyways. Thanks guys.
Old Apr 26, 2005 | 09:57 AM
StrikerX's Avatar
It would heat up at idle because
1. the radiator fan is not on
2. the car is not moving therefore the cooler air is not coming into the front of the car cooling off the radiator and the engine.
I hear that on alot of older american cars ppl would remove the thermostat altogether.
You heater probably doesn't blow that hot niether, maybe hotter when idleing and cooler when driving.
Old Apr 26, 2005 | 10:36 AM
Honteggie's Avatar
Exactly. I guess I just don't see how the thermostat sticking open would cause it to run so cool when driving. Just kinda uncanny. Oh well, time to go fix it.
Old Apr 26, 2005 | 10:56 AM
StrikerX's Avatar
lets us know if it fixes your problem.
93lsv_turbo
Jul 1, 2012 05:54 AM
nicknack25
Feb 13, 2012 09:27 PM
invisible
Dec 1, 2006 12:35 PM
homeskillet
Dec 24, 2004 09:22 PM
spart
Feb 27, 2002 05:31 PM
