Heat Shields
Old Oct 30, 2001 | 02:33 PM
IntegraGSR23's Avatar
Default Heat Shields
My heat sheilds are rattling against my exhaust, it is very annoying. Would you advise removing them or not?? Would it harm anything? I keep taking it back and forth to the shop that installed my exhaust to get it adjusted, but it's still there. He gave me the option of taking the heat shields off, so thats why I am posting..
Old Oct 30, 2001 | 02:37 PM
Phat Corolla's Avatar
New User
Default Re: Heat Shields (IntegraGSR23)
I have most of my heat shields off. I had that rattle at 3500 RPM that everyone talks about and I removed my cat heat shields first. This had no effect on the rattle, so I took the heat sheilds off of the header itself. This seems to have done the trick. Give it a try. Be aware though that If you take off your header sheilds, the temp under the hood will rise though.
Old Oct 30, 2001 | 02:58 PM
Default Re: Heat Shields (Phat GS-R)
My header heat shields are already off, I have a DC header. So taking the heat shields off should not harm anything, huh? I am prolly gonna take the one's around the piping off first then cat, etc.. My main concern was the one around the gas tank area. Did you remove that one as well?
Old Oct 30, 2001 | 03:00 PM
New User
I have not removed that one. I can't imagine that it's a really big deal. Do not take only my opinion on this though. Wait until someone else has put in their $.02 before you do it.
Old Oct 30, 2001 | 04:04 PM
1fastGSR's Avatar
New User
I removed all the heat shields under the car after installing my Comptech exhaust beacuse of rattling. I have them off for almost 1 yr. now without any problems. I go under the car about once a month to check if anything is getting damages or melting because of the heat and no problems yet.
Old Oct 30, 2001 | 05:04 PM
fsarfino's Avatar
this is a common honda problem I have owned 4 honda's and every single one does this and on every one i've removed em with no problems
Pr0ject93hb
Mar 4, 2007 11:09 AM
intxactdgsr
Mar 21, 2005 05:38 PM
AznJohn33
Jan 3, 2004 07:44 AM
Brasspremier
May 3, 2003 04:06 PM
Ryuji
Dec 27, 2001 12:25 PM
