header question
Old Jun 4, 2007 | 06:03 PM
shadydb7's Avatar
Default header question
which header do you think will make more power?.
1)JDM ITR 98+spec 4-into-1
2) DC Sports 4-into-1 header
both have 2.5 inch collectors
the motor is a 96 USDM B18c1
its got:
1) AEBS Typhoon IM
2)Skunk2 68mm TB
3)honda heatshield gasket
4)Skunk2 stage 2 cams w/retainers
5) spoon 2mm headgasket
6) JDM ITR OO pistons
compression should be at about 11.7:1
so which header is better or make a suggestion if neither is good
Old Jun 4, 2007 | 08:37 PM
alexisthemovie's Avatar
I have the DC Sports 4-1 because it is carb legal. They are pretty much the same thing though.
Old Jun 4, 2007 | 09:08 PM
ABCVTEC's Avatar
Default Re: (alexisthemovie)
The DC Sports 4-1 is an ITR replica. So yeah they are the same thing.
Old Jun 4, 2007 | 09:28 PM
letsdrive's Avatar
the JDM 4-1 DC is not carb legal.
Old Jun 5, 2007 | 06:34 AM
Liu Kang's Avatar
Default Re: (letsdrive)
they are pretty much both going to put out the same, as for carb legal, Ca sucks ***, I don't even need emissions here in Carbon county, meaning I can take my cat off or gut it and still be fine...
Old Jun 5, 2007 | 06:40 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Liu Kang)
The appropriate question is:
"Which header will make what type of powerband?"
Old Jun 5, 2007 | 07:38 AM
VTECth1s's Avatar
Another Q in regards to those two header, how is the ground clearance? say if your lowered, with about 1/8" - 1/4" wheel gap. On my 4-1 header, ground clearance was horrible, and the tires were not even tucked, and the entire bottom of the header was grinded down flat. Are the 4-2-1 header much better when it comes to ground clearance issues, cuz the 4-2-1 header don't overlap unlike the 4-1 header, sorry to thread jack.
Old Jun 5, 2007 | 07:41 AM
Ek Forever y0!
Default Re: (VTECth1s)
Most 4-2-1 headers have better ground clearance.
it's all in the design, i've seen 4-1 headers with excellent ground clearance.
it depends if the 4-1 header is made like
00
00
or like this :
0000
^that's if you're looking at the piping from the back of the car.
Old Jun 5, 2007 | 10:57 AM
VTECth1s's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Most 4-2-1 headers have better ground clearance.
00
00
or like this :
0000
^that's if you're looking at the piping from the back of the car.</TD></TR></TABLE>
mine was like this,
00
00
Ended up grinded flat , but I definitely prefer the 0000 design, like Hy-tech, rage, etc and have that pattern but pricey. I kno theres a few other companies that have 4-2-1 header in the 0000 design correct?
Old Jun 5, 2007 | 11:09 AM
Padawan's Avatar
Darth ModerVader
Default Re: header question (shadydb7)
If you've spent that much on your setup already, why limit its potential with the header? I'd go for something that will perform better, such as an SMSP.
Old Jun 5, 2007 | 03:43 PM
1turbodc2's Avatar
Default Re: header question (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">If you've spent that much on your setup already, why limit its potential with the header? I'd go for something that will perform better, such as an SMSP. </TD></TR></TABLE>
i agree with you 100 percent!
cakes
Northern California (Sales)
Jun 26, 2011 06:30 PM
mcbaine
Nov 11, 2007 11:00 AM
ballinthavx
Apr 5, 2006 02:56 PM
Lil Corb
Jan 17, 2005 01:01 PM
Rratedcivichatch
Dec 26, 2002 10:43 AM
