do i have to remove the dashborad?
Old May 28, 2007 | 09:09 PM
LILSOWEK's Avatar
Default do i have to remove the dashborad?
do i have to remove the dash board to replace the ecu wiring, here are some pics of the wires that are cut and that i have to replace, i really have no idea on to replace these wires. this is my first project car, can you guys help me out?
[IMG][/IMG]
Old May 28, 2007 | 09:35 PM
GsrIntegra789's Avatar
Default Re: do i have to remove the dashborad? (LILSOWEK)
or you can find the stock clips and wire each wire one by one. Itll probably take some time
Old May 29, 2007 | 02:11 PM
LILSOWEK's Avatar
bump
Old May 29, 2007 | 09:28 PM
LILSOWEK's Avatar
come on guyz i need help
Old May 29, 2007 | 09:31 PM
1.8L_allmotormilitia's Avatar
good luck.
Old May 29, 2007 | 09:33 PM
nokturnal_munkeeboy's Avatar
Default Re: do i have to remove the dashborad? (1.8L_allmotormilitia)
damn that *** up
Old May 29, 2007 | 09:49 PM
LILSOWEK's Avatar
do you guyz know if i have to take out the dash to swap the wires?
Old May 30, 2007 | 02:07 AM
JDMorgan's Avatar
yea. you have to take out the seats, carpet, dash, and interior panels. it might be a pain but i bet there is more screwed up wiring if you look a little harder. what year is this car? looks like maybe a 94-95 ls or gs? rip the abs out of this junker, if you plan on putting a vtec engine in it go buy a 94-95 gsr harness now.
btw the dash is only like 6 bolts, dont be scared to remove it. lol
Old May 30, 2007 | 04:58 AM
1998b18c1's Avatar
You're going to have to pull all of your instrument cluster, radio, and a/c panel then you can reach all the clips and wire ties used to secure that part of wire harness. goodluck
Old May 30, 2007 | 02:05 PM
LILSOWEK's Avatar
Default Re: (JDMorgan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMorgan &raquo;</TD></TR><TR><TD CLASS="quote">yea. you have to take out the seats, carpet, dash, and interior panels. it might be a pain but i bet there is more screwed up wiring if you look a little harder. what year is this car? looks like maybe a 94-95 ls or gs? rip the abs out of this junker, if you plan on putting a vtec engine in it go buy a 94-95 gsr harness now.
btw the dash is only like 6 bolts, dont be scared to remove it. lol</TD></TR></TABLE>
its a 95 ls, im looking to buy the gsr wiring harness
Old May 30, 2007 | 02:10 PM
JDMorgan's Avatar
its a pretty straight forward swap as long as you get the entire harness. i went and found a crashed gsr and pulled every single wire out of the car as one big piece then just laid it out in my car and was done. since then i actually decided to make a custom harness tho. lol.
Old Jun 1, 2007 | 11:51 PM
LILSOWEK's Avatar
even though my car has no battery do i still have to disconected the air bags before i remove the dashboard????
Old Jun 2, 2007 | 12:21 PM
JDMorgan's Avatar
you have to disconnect the airbags only because you have to remove them. one comes out to take the steering wheel out, the other comes out with the dashbord itself.
Old Jun 2, 2007 | 01:01 PM
LILSOWEK's Avatar
ok thanks
Old Jun 2, 2007 | 01:26 PM
NTX
Guest
Posts: n/a
Default Re: (LILSOWEK)
Old Jun 2, 2007 | 01:39 PM
LILSOWEK's Avatar
i already bought the gsr ecu and the engine harness and i have a gsr engine and tranny ready to drop in, i think now i need the under the dash wiring and the radiator. The car is 95 ls and its salvage, im having trouble deciding if to sell it or fix it. what do you guyz think?
Old Jun 2, 2007 | 02:10 PM
RCautoworks's Avatar
Default Re: do i have to remove the dashborad? (nokturnal_munkeeboy)
The ecu wiring goes all the way back underneath the dash, yes you have to remove the dash, the peddles and anything else. Its not easy at all.
Old Jun 2, 2007 | 04:08 PM
JDMorgan's Avatar
a 98 ls rolling shell in good shape is $1000. do u really think it's worth it to fix your ls considering done with a gsr motor it will be worth the value of the gsr motor? not being a dick. just saying shells are cheap, find a clean title car that is actually what you want. part your shell out and make some cash to throw towards a clean title one.
Old Jun 2, 2007 | 04:21 PM
LILSOWEK's Avatar
well i might just fix it up with an ls ecu and engine and see if get win a couple hundred from what i got it.
w.a. i got the scews off the the bottom of the dash board, but is there screw for the dash board behind the cluster, the clock, a/c controller??? cause the dash board is loose from the bottom but i cant find the screws holding the top of it.
Old Jun 4, 2007 | 04:00 PM
LILSOWEK's Avatar
need ^
Old Jun 4, 2007 | 08:59 PM
JDMorgan's Avatar
bolt behind the clock and the cables for the heat hold it in. sides of the dash too. and 2 bolts under the airbag.
Old Jun 5, 2007 | 04:31 PM
LILSOWEK's Avatar
thanks i'll try it right now
MrMug3n
Mar 15, 2008 08:08 PM
xluben
Nov 29, 2006 04:59 PM
gianinline
Oct 16, 2005 08:03 PM
ragejed
Nov 11, 2003 01:20 PM
mantic6t9
18
Feb 26, 2003 10:41 AM
