D16Y7 Stock Header Question
Can the stock header be separated from the catalytic converter easily? Is it held on with bolts? I have a cracked header and I'm wondering if I need to replace just the top header part or the whole unit.
Re: D16Y7 Stock Header Question
I agree with nub.
Be careful if you replace yourself as there should be an O2 sensor in the cat...make sure not to damage it when you remove the cat/manifold as a new O2 sensor can be a bit expensive depending on what you buy.
Rotella-t
Honda Civic (2001 - 2005)
05-16-2008 10:28 PM
