Headbolts?????????
Old Oct 11, 2004 | 02:14 PM
vangc6780's Avatar
Default Headbolts?????????
please i need to buy some new headbolts for an integra gs. its a 1990 and i search all over the net for some descent cheap bolts. the dealership want $200 plus for the headbolts....
Old Oct 11, 2004 | 02:34 PM
purplegsr's Avatar
Default Re: Headbolts????????? (vangc6780)
http://www.acuraparts247.com
If you have the part #s, just type those in, if not, put in your model, year, transmission and then click on select part (without searching), then click on cylinder head or cylinder head cover. The cylinder head bolts you are probably talking about range from $2-$5 on this site, even the bolt studs where the header attaches are only $5 each. It will show you a diagram so you can figure out which parts you need.
Old Oct 11, 2004 | 02:44 PM
vangc6780's Avatar
Default Re: Headbolts????????? (purplegsr (Exospeed))
thank you!!!!!!!!!!!!!!!!!
honda-tech users are the best in the world.............
Old Oct 11, 2004 | 02:57 PM
purplegsr's Avatar
No problem, if you get the part #s and want to compare prices, you could also hit up Len on H-T or Vern (92GS-R) on g2ic.com (he is the parts guy for Power Honda in Costa Mesa) and see if they can get it cheaper for you.
TECKSTEREX
20
Mar 21, 2018 05:43 PM
moddage
Jun 25, 2010 06:44 PM
Shft@9GSR
May 24, 2002 07:17 AM
