NITROUS KITS!!!
Old Feb 15, 2004 | 10:43 AM
TO_SLOWGSR's Avatar
Default NITROUS KITS!!!
I am thinking of spraying the gsr, i want to go with a 50-60 shot. I don't know if i should run a dry kit or a wet kit, which one should i run? Also what kit would you recommend (nitrous express, zex, nos,ect.) Also what kind of supporting mods do i need to run a 50 to 60 shot? thanks for all the info guys i sure it will all help
Old Feb 15, 2004 | 10:47 AM
lke2drvgsr's Avatar
Default Re: NITROUS KITS!!! (TO_SLOWGSR)
read the articles in http://www.team-integra.net on nitrous, youll be able to decide on your own what's best
Old Feb 15, 2004 | 10:57 AM
Vtecfool's Avatar
Default Re: NITROUS KITS!!! (lke2drvgsr)
you should pick up last month's issue of Super Street, they did a whole article on Nitrous and accessories. If i ran i would run with Zex
Old Feb 15, 2004 | 11:13 AM
Kendall's Avatar
I ran a 50 shot wet kit and had decent results with it, but it was a completely custom setup. Most of the people that I know down here are having success with the Zex kit. It's worth looking into, but I suggest you research the subject a bit more.
Old Feb 15, 2004 | 11:58 AM
TO_SLOWGSR's Avatar
Default Re: (Kendall)
So you guys think i should go with the zex kit. (wet or dry) ? Also i was wondering ins't the zex kit rated at the flywheel? If so wouldn't this kit be the slowest one on the market???
Old Feb 15, 2004 | 01:43 PM
92AztecGsr's Avatar
Im running an 80 shot wet kit from Nitrous Oxide Systems. I feel this is a very good kit, I have had alot of success with it.
Old Feb 15, 2004 | 02:33 PM
zilverz's Avatar
you have anything like a VAFC to richen the fuel at WOT ?.. if not better read up on nitrous and what going lean in the combustion chamber can do to the engine. REAd Read Read (:
Old Feb 15, 2004 | 02:41 PM
DOHChi's Avatar
Default Re: NITROUS KITS!!! (zilverz)
I run a 75 shot from NOS its a dry kit. Its kinda dumb of me running that much, but it hasnt given me any problems so far. I rarely use it though only when I run my car. Remember nitrous is useful as long as the user is educated on it. You gotta read about it more, and do more research. We can help you so much, but its really up to you on how you wanna run ur setup.
Old Feb 15, 2004 | 03:01 PM
92AztecGsr's Avatar
Yea def research it, I researched for about 2 years before I went with it, my bottle only is used at the track.
Old Feb 16, 2004 | 12:19 PM
TO_SLOWGSR's Avatar
Default Re: (92AztecGsr)
Well it seems that most people like the nitrous express kit! I am not really sure on the one is for me but it looks like it will be the nx kit. Does anyone here run the nitrous express kit? If so how is and is it worth looking into more?
Old Feb 16, 2004 | 01:03 PM
BrownGSR's Avatar
Default Re: (TO_SLOWGSR)
a simple anwser to a simple question, zex dry shot
Old Feb 16, 2004 | 01:26 PM
P1mpSlap's Avatar
I'd run the NOS plate kit. I used to know a guy spraying a 120 shot with that kit (other mods too) and it was a beast.
Old Feb 16, 2004 | 02:33 PM
TO_SLOWGSR's Avatar
Default Re: (P1mpSlap)
I was looking at the zex kit but everone tells me that the hp rating is a the flywheel. Nitrous express and nos say thier kit if its a 60 shot the it withen 2% of the hp rating at the wheels. Also the shark nozzels that come with the nx kit are the best on the market because they equal the fuel and the gas evenly not to lean or to rich. It all comes down to the zex kit and the nx kit i'm am stuck between the two.. Also what would i need to run a 60 wet on the zex kit (fuel pump, fpr,etc)? or will it run off my stock fuel system??
Old Feb 16, 2004 | 03:54 PM
MooreBoost's Avatar
Zex Wet. Period.
Old Feb 16, 2004 | 04:08 PM
integraGSR1's Avatar
depends on how serious you are. my first kit, i went with the ZEX kit, it was simple to install and i was running a 75 shot dry. pretty simple setup. but if you a bit more serious, i would look into the plate systems for the GSR.
TO_SLOWGSR's Avatar
Default Re: (tegunderpressure)
So for you guys that are running the zex kit , what times are you running? I want to be some where in the mid to high 13's will a 60 shot wet on a zex kit put me thier with i/h/e??
Old Feb 16, 2004 | 05:47 PM
MooreBoost's Avatar
Depends on the driver. But I would say its definatly do-able.
Old Feb 16, 2004 | 11:06 PM
ECKOTYPER's Avatar
i have a 50 shot single fogger wet nx kit on the built gsr right now... id have to tell ya, that wet is worth it, dont spray if u ahve a chipped ecu, if u accidently overrev while shooting, your gonna need a new motor =D hasnt caused me any problems so far... im changin to 75 shots at the tracks, hoping low 13's or in the best scenario a 12.9 with a semi built gsr squeezing on 22 inch mickeys, and gutted as hell hehe
Old Feb 17, 2004 | 12:02 PM
TO_SLOWGSR's Avatar
Default Re: (ECKOTYPER)
I think that i am going to go with the ZEX kit, a local shop around here recommended it. I will be running the 65 wet shot more then likely. Also i have a friend that is about to spray as well, he only has a cat back and a cai but has a stock header will he be ok or will he have to change to a aftermarket first. I wasn't sure on it so i did not answer. so any info will be great...
Old Feb 18, 2004 | 07:50 PM
joek84's Avatar
no one recomends direct port? I recommend you buy my direct port from me, and to research more.
Old Feb 18, 2004 | 07:53 PM
revhigh89's Avatar
Old Feb 18, 2004 | 07:56 PM
typeRSXS's Avatar
for the people that ran 50+ shots, what times have u gotten on a GSR or type R?
Old Feb 18, 2004 | 08:00 PM
Kendall's Avatar
I've run mid 13's in my ITR, but this is with I/H/E and some weight reduction as well as the 50 shot.
Old Feb 18, 2004 | 08:09 PM
stp_vtec_boi's Avatar
umm il say go with what u want but il go with tha wet kit ...
Old Feb 19, 2004 | 04:01 AM
MooreBoost's Avatar
Default Re: (stp_vtec_boi)
For a 50 shot I think DP is overkill. But its always nice.
teefunk01
Northeast (Sales)
Jul 17, 2007 03:51 AM
1.8EG-T
May 20, 2003 12:09 PM
blacklude
Oct 14, 2002 01:57 PM
NeedMOPower
Jan 8, 2002 12:15 PM
