GSR misfiring?
Old 03-10-2009, 08:46 PM
vietxdragon's Avatar
Default GSR misfiring?
My 95' GSR is misfiring and is definitely on 3 cylinders.
Recently replaced
-Distributor OEM
-Spark Plugs NGK
-Spark Plug Wires NGK
-O2 sensor NGK
-TPS sensor NGK
compression was 180-180-180-170
Theres black soot on my rear bumper and coming out of my exhaust, which i thought is unburnt fuel. I can't figure out why my car is misfiring. My car is throwing no CEL's. Checked CAM timing. What else can i check?
Old 03-11-2009, 07:17 AM
mouab18c1's Avatar
Default Re: GSR misfiring?
Jump the CEL. and get back to us
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
Old 03-11-2009, 09:56 AM
i've already done it, nothing at all. I can't figure out why its misfire
Old 03-11-2009, 10:40 AM
mouab18c1's Avatar
did you calibrate your tps when you switched it out?
Old 03-11-2009, 02:36 PM
I'm guessing its somewhere in the ignition system thats messed up or something, throwing no codes. I wonder if the ICM in the distributor is bad ?
Old 03-12-2009, 06:46 AM
mouab18c1's Avatar
it could be..check for corrosion
Old 03-12-2009, 09:26 PM
yeah, it was an OBD2 - but i repinned it to obd1 plugs and it ran fine afterwards. Started misfiring now though. I'll try swapping the ICM's and see if it fixes the problem. I'll update this thread in the evening probably
whiterichard70
02-09-2013 03:05 AM
Civic Hybrid
10
08-17-2008 09:35 AM
crazyness462
03-14-2008 09:09 PM
bshshondaman06
04-19-2007 09:01 AM
b16b18
09-06-2006 12:56 PM
Quick Reply: GSR misfiring?
