gsr code 6 need help!!!
Old Jun 23, 2010 | 10:34 PM
kevinEJ's Avatar
Default gsr code 6 need help!!!
i replaced my rear motor mount today then... my car threw code 6 . i think it threw the code because the plug ripped out. or can it be something else.
im new to integras HElp will be appreciatied =]
Old Jun 23, 2010 | 10:37 PM
crazyheadrush's Avatar
Default Re: gsr code 6 need help!!!
Code 6 Engine coolant temperature. Its the single plug that is under the distributor, about the size of a dime, either white or black in color.
Old Jun 23, 2010 | 10:41 PM
kevinEJ's Avatar
that means i have 2 buy a new ect? or is it because the plugged is ripped and it cant be plugged back in?
Old Jun 23, 2010 | 10:45 PM
Im pretty sure its the plug, u can use the same one from a vtec plug, the green one, just splice it and adapt it.
Old Jun 23, 2010 | 10:47 PM
kevinEJ's Avatar
alright thanks =] i thought it was the plug also i also ran a wire making both wires touch so the fan can always be on .. u think that does anything? done before the plugg ripped out and no cel
Old Jun 23, 2010 | 10:49 PM
Does nothing but tell the ecu "im hot cool me down" triks it into thinking its temperature is up.
Old Jun 23, 2010 | 10:51 PM
If and when u put the plug back make sure its like the old one. If u flip the wires around then ur fan may never come on and thats a problem. Theres a negative and positive to it.
Old Jun 23, 2010 | 10:53 PM
kevinEJ's Avatar
ahhh **** is there any way i can tell which one is positive and negative cause i cant tell from the plug i had the wires completely came out .. and if i plug it back in the cel will go away?
Old Jun 23, 2010 | 10:54 PM
Blue positive, black negative.
Old Jun 23, 2010 | 10:56 PM
kevinEJ's Avatar
how do i tell from the sensor ?
Old Jun 23, 2010 | 10:57 PM
Ehhhh thats were it gets kinda difficult. I can take a look at mine and let u know.
Old Jun 23, 2010 | 11:07 PM
kevinEJ's Avatar
its ok ill probally just burrow my friends plug and wire it up will the cel go off after this though?
Old Jun 23, 2010 | 11:09 PM
Yup.
Jesse_Boyer
12
Dec 24, 2024 02:21 AM
liljohn850
15
Jul 9, 2011 12:19 PM
jaxx4k
Dec 6, 2004 07:25 PM
ki3t
Mar 29, 2004 07:41 AM
wu tang
Apr 5, 2003 07:00 PM
