auto to manual?
auto to manual?
anyone done this? car is a 96 hatch. know i need the pedal assembly and clutch lines and master cylinder. what else....besides a manual tranny and linkage of course.
Re: auto to manual? (Spade)
yeah probably, but i am just wondering about things other than engine parts. cause ill be getting a swap so ill get anther ecu later anyways.
Re: auto to manual? (Aceman64)
its a real pain...you need the manual ecu, the linkage, all new pedals, mounts, cut into the floor base, manual tranny etc. i would only do it with a complete swap. its pointless for a d series motor.
Re: auto to manual? (maks)
what do you have to cut the floor base for? see im thinking if i have the pedals, master cylinder and all the lines it should just bolt up right? dont know though thats why im askin.
Re: auto to manual
I did it on my 93 ex. You would need to get the following parts:
Master cylinder
Slave cylinder
brake pedal
clutch pedal
clutch resorvoir
manual tranny
shift linkage
shifter
shift boot
clutch
flywheel
flywheel cover
flywheel cover bolts
manual Ecu
clutch lines
manual trans. Mounts
The best thing for you to do is go to the dealer and ask them for a print out of the following diagrams:
-shift linkage
-mastercylinder/slave cylinder...this one should show you all the lines and misc. bolts that you would need.
-pedal assy. You will need alot of bolts and brackets and screws that the diagram will show.
I think thats about it. Good luck
Master cylinder
Slave cylinder
brake pedal
clutch pedal
clutch resorvoir
manual tranny
shift linkage
shifter
shift boot
clutch
flywheel
flywheel cover
manual Ecu
clutch lines
-shift linkage
Re: auto to manual (td04civic)
yeah i just bought a ek that was auto cause there hard as hell to find . and im gonna change it. my friend has a lot of the parts and so it shouldmt be too bad. thanks for the help guys.
