getting abs codes
Old Sep 23, 2004 | 08:58 PM
WhiteGSR95's Avatar
Default getting abs codes
ok i have a 95 gsr with a 97 gsr engine.
i went to my car got the a wire a did what i had to do so my abs light would flash with my problems. so i got the flashes and all.
i got code 4 and code 8. at 1st i thought that it was 14 and 8 but i read the article and it said that thers not long flashes which means that theres no code over 9.
so heres my question on this thread https://honda-tech.com/zerothread?id=978933 it has for example 4 8 wheel sensor LR. does this mean that the code i got is for the wheel sensor LR or could it b any of the wheel sensors and any of these
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check ?
i hope yall understood what im trying 2 say
thanx
Old Sep 23, 2004 | 11:05 PM
WhiteGSR95's Avatar
Old Sep 24, 2004 | 01:26 AM
iiilgsrlll's Avatar
Default Re: getting abs codes (WhiteGSR95)
Do you have the same wheel/tire size all the way around?
Old Sep 24, 2004 | 05:19 AM
JimBlake's Avatar
When you read the ABS codes ('94-'97) you gotta pay attention to the spaces between the flashes. A 1-second space is between the 1st & 2nd digit of the code. A 5-second pause before showing an entirely new code.
So if it's a 1-second pause between 4 & 8, that's 4-8 which is the left rear wheel sensor. Take off that wheel & brake rotor. Check out the sensor, sometimes it gets full of magnetic crud, so you can probably clean it. Then check out the wiring from the sensor - look for breaks. The wire goes into the body, there's an orange plug somewhere. Pull up trunk carpeting & I think(?) there's a metal thing covering up the wire as it goes across to the ABS module at the RR fender.
If it's REALLY a code starting with 8, you can hope that it's a fluke. Check for loose plugs at the ABS unit, but those usually mean your ABS computer is fried.
Old Sep 24, 2004 | 10:22 PM
WhiteGSR95's Avatar
ill check it out tomorrow.
pinoyboy204
Feb 23, 2007 03:55 PM
951dc5
Apr 9, 2006 03:21 PM
HOOKSH
Feb 11, 2005 05:55 AM
gsr squirrel
Mar 14, 2003 10:19 AM
