Gauge Cluster
Old Aug 10, 2005 | 07:32 AM
iTzKeviN's Avatar
Default Gauge Cluster
so my speedometer went out bout 4 weeks ago, when i had this massive electrical problem in my car. after the fix, everythin worked except for the speedometer inside the gauge cluster. so i was wonderin wat i need to do in order to fix the problem. also, is it possible to just replace the speedometer off an LS,GS,RS instead of the whole cluster?? cuz GSR clusters are expensive n hard to find.. (i have a 92 GSR)
Old Aug 10, 2005 | 06:44 PM
LS_teg's Avatar
Default Re: Gauge Cluster (iTzKeviN)
damn thats a good ? are you sure that the problem is in the cluster. are you sure its not in the wiring that plugs into the back of the cluster. and yea its going to be hard to find a new cluster for a 92 gsr
goodluck on your cluster
Old Aug 10, 2005 | 07:07 PM
vice versa's Avatar
Default Re: Gauge Cluster (LS_teg)
would it be the speed sensor?
thats 200 bucks right there
Old Aug 10, 2005 | 07:15 PM
. a d a m's Avatar
Throwing any ecu codes?
Then we'd be able to tell if its your speed sensor.
Old Aug 10, 2005 | 08:22 PM
mrdeadman's Avatar
They let me pick
you can take out just the speedo. a guy on here did it and wrote up a pretty good how-to on rolling back the odometer, or forward, in case you got a new cluster. here's the link. https://honda-tech.com/zerothread?id=837111 there's a picture of just the speedometer.
Old Aug 10, 2005 | 08:35 PM
53JDMDC2's Avatar
what was the electrical problem cause it could have burned up some of the electronics in the cluster?
Hill4589
May 16, 2018 08:29 AM
Circa
Jun 9, 2006 10:59 AM
ronintegra
Jan 3, 2006 12:10 PM
STPREZ
Jan 15, 2005 02:42 PM
