fuse keeps blowing
Old Sep 14, 2009 | 08:00 PM
barnie's Avatar
Icon2 fuse keeps blowing
ok in my 95 teggy my friend locked my keys in the car while it was on but not running, so my head unit and everything was on. then about 4 or 5 hours later i finally got my spare key and now my head unit and clock arent working. it's the 7.5 fuse under the hood thats blown and right when i stick a new fuse in it immediatly blows. i disconnected my head unit and its still doing it. and i couldnt find any bare wire touching anything so far.
has anyone else had this problem before or know what it could be?
thanks for the help.
Old Sep 14, 2009 | 08:11 PM
mrdeadman's Avatar
They let me pick
Default Re: fuse keeps blowing
Which fuse is it for?
Old Sep 14, 2009 | 08:26 PM
SpEeDyX's Avatar
just throwing this out there, but you disconnected the battery when replacing the fuse right?
Old Sep 14, 2009 | 08:49 PM
barnie's Avatar
it's the 7.5 back up fuse under the hood
yupp, right when the battery plugs in it sparks and blows.
Old Sep 14, 2009 | 10:54 PM
white_gsr's Avatar
Hmmm......Thats weird. Did you do anything else to it when you were trying to get in?
Old Sep 15, 2009 | 07:53 AM
barnie's Avatar
no i dont think so lol. i'll probably end up loosening the dash up today and checking all the wires and what not.
Old Sep 15, 2009 | 12:08 PM
white_gsr's Avatar
lol man that is going to suck when you find out it was something EASY lol but Good luck.
Old Sep 15, 2009 | 02:54 PM
bigislandc2's Avatar
that 7.5 fuse is also the resett for the ecm. when you blow a fuse you have a short to ground.
Old Sep 15, 2009 | 04:03 PM
follie gatts's Avatar
you say head unit, do you have an amp wired to your battery? you should check for continuity between your engine bay grounds, especially the negative terminal on the battery to the chassis where it bolts to it. if you pulled both terminals the negative terminal wire could not be contacting the battery properly.
Old Sep 16, 2009 | 09:42 PM
barnie's Avatar
well i dont know what the heck it was but i messed with the wires and it's working now. thanks for the help. i'm going on a 5 hour trip tomorrow and that would be pretty shitty not having music lol.
dhealey
Honda CR-V & Element
11
Jun 5, 2024 06:31 PM
niceprelude
Sep 2, 2011 06:58 AM
ThinkRevolution
14
Aug 10, 2008 04:35 PM
ahloung
12
Mar 16, 2006 08:00 PM
4doorRS5spd
Audio / Security / Video
Sep 6, 2002 08:29 PM
