which fuse for DA integra for compression test ?
Old Dec 8, 2005 | 03:37 PM
redDAinteg's Avatar
Default which fuse for DA integra for compression test ?
Everywhere I read says to remove the 15amp fuse but they are all for DC integras. Which fuse would I remove for a DA integra so no fuel will be sprayed into the cylinders. I want to know because last time I did a compression test without removing the fuse, my car wouldnt start anymroe because I blew the coil.
Old Dec 8, 2005 | 03:58 PM
92integraVTECgsr's Avatar
Default Re: which fuse for DA integra for compression test ? (redDAinteg)
1. Remove the Main Fuel Relay Under the Dash (beside the steering wheel column)
2. Disconnect the distributor connections (2 of them)
And dont forget to hold the gas pedal to the floor while you're cranking the motor.
Old Dec 8, 2005 | 04:05 PM
redDAinteg's Avatar
Default Re: which fuse for DA integra for compression test ? (92integraVTECgsr)
where exactly is the main fuse relay ? and what amp number is it ?
Old Dec 8, 2005 | 07:07 PM
Johnny_Rocket's Avatar
Default Re: (4sd4dr)
I just unhooked the dizzy harnesses and pulled the fuel pump fuse out under the hood... maybe I did it wrong lol
Old Dec 8, 2005 | 07:53 PM
thelate1's Avatar
Default Re: (JohnnyH)
i just unplugged my fuel pump........seemed to work ok.
Old Dec 8, 2005 | 09:05 PM
redDAinteg's Avatar
Default Re: (thelate1)
ok I still dont really know where the main fuse relay is? maybe im not looking hard enough ? can someone take a picture.
Old Dec 8, 2005 | 09:40 PM
Default Re: (redDAinteg)
ok.. DA right? the Main Fuel Relay is under the dash panal that covers the steering column.
I think there are 4 screws holding this panel in. do you know what im talking about? its the only 1 panel there.
Now once you take that off. if you are in the seat, look towards the top inbetween the steel brace or whatever you wanna call it. You will see a Black relay that says like 15amp i think it is. it is to the LEFT of the steering column, and its the only one in that area. you can see it if you are looking at it like you were sitting in the seat with your head kinda bent over tring to look under the dash. It is the only BLACK Relay in the area.
understand? you need to unclip the 2 plastic clips that attach to the relay, and push the clearish colored socket down and off of the relay. the relay is screwed onto the frame. once you unplug it, you are good.
let me know.
Old Dec 9, 2005 | 11:12 AM
redDAinteg's Avatar
Default Re: (92integraVTECgsr)
once I remove the main fuse relay and the 2 distributer connections, do I also have to remove the ECU fuse under hood?
Old Dec 9, 2005 | 11:19 AM
no.. the manual says you dont.
Old Dec 9, 2005 | 11:32 AM
redDAinteg's Avatar
I should be staright with just doing that and no chance of my coil going out this time ?
Old Dec 9, 2005 | 11:45 AM
DA1's Avatar
DA1
What he said.
Old Dec 9, 2005 | 03:57 PM
Muckman's Avatar
Moderator in Chief
All you need to remove is the 15amp PGM-FI fuse under the hood. It will disconnect the power from the ECU and the fuel pump wont prime without the ECU. You dont have to touch the distributor or the main relay which is harder to get to than the ECU fuse.
Old Dec 10, 2005 | 10:53 AM
redDAinteg's Avatar
Default Re: which fuse for DA integra for compression test ? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">All you need to remove is the 15amp PGM-FI fuse under the hood. It will disconnect the power from the ECU and the fuel pump wont prime without the ECU. You dont have to touch the distributor or the main relay which is harder to get to than the ECU fuse.</TD></TR></TABLE>
You know if it was that easy on a DA, I think I wouldn't have made this thread in the first place.
Old Dec 10, 2005 | 01:35 PM
ya our DA and DB2 don't have that fuse under the hood.
Old Dec 10, 2005 | 01:59 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">1. Remove the Main Fuel Relay Under the Dash (beside the steering wheel column)
wow you do it the hard way. all you need to do is unplug the connections to the dizzy and unplug the 10amp ecu fuse in the engine bay fuse box
Old Dec 10, 2005 | 02:02 PM
Default Re: which fuse for DA integra for compression test ? (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">wow you do it the hard way. all you need to do is unplug the connections to the dizzy and unplug the 10amp ecu fuse in the engine bay fuse box</TD></TR></TABLE>
ya.. not that hard.. just 4 extra screws to take the panel off..no big deal for me.
Old Dec 10, 2005 | 02:11 PM
Muckman's Avatar
Moderator in Chief
The ECU has to be on a fuse somewhere. Just remove it, system disabled.
Old Dec 10, 2005 | 02:13 PM
redDAinteg's Avatar
Will that way work? If so that way is alot easier.
Old Dec 10, 2005 | 02:58 PM
projectTeG's Avatar
easier to just open the engine bay fuse panel and pull the 10amp fuse.lol<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">
Will that way work? If so that way is alot easier.</TD></TR></TABLE>
yes that will work you disable the ecu and no feul will be pumped into the engine. and unplugging the connectors to the dizzy will stop the igniton and won't fry the coil. i did the same thing as you...i did my first compression test and forgot to unplug the dizzy and i fried my coil. that was a hundred bucks that i didnt have to spend that day...haha
Old Dec 10, 2005 | 03:13 PM
redDAinteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">easier to just open the engine bay fuse panel and pull the 10amp fuse.lol
yes that will work you disable the ecu and no feul will be pumped into the engine. and unplugging the connectors to the dizzy will stop the igniton and won't fry the coil. i did the same thing as you...i did my first compression test and forgot to unplug the dizzy and i fried my coil. that was a hundred bucks that i didnt have to spend that day...haha</TD></TR></TABLE>
alright thanks for help!
D12Beast
16
Feb 1, 2011 04:21 PM
92hybridAccord
Apr 6, 2005 10:09 AM
SonicBlueGSR
Jun 10, 2003 08:57 PM
dutchman5
Mar 9, 2003 07:16 PM
