Main Relay Issue?
Main Relay Issue?
The fuel pump won't prime. I checked the fuses and grounds, they're all good. I checked to see if it was getting any voltage, and it wasn't. I tested the main relay for continuity, its fine. I jumpered the 5 and 7 ports in the main relay plug, still no voltage. I put a multimeter up to the main relay plug and it isn't getting any voltage at all. Any ideas?
Re: Main Relay Issue?
There are two metal test tabs at the top of each fuse. Check for voltage to body ground at BOTH tabs individually. Does one of the tabs of installed fuse 31 have voltage?
With the key in ON(II), do both tabs of fuse 24 have voltage?
On fuse 31 both tabs have voltage to ground, but when you put a probe on both tabs there is no voltage.
On fuse 24, there is voltage to ground on the tab that is closest to the floor, but none on the one that is closest to the top.
Now that its working its been kind of lagging. It takes a while for the fuel pump to kick on once I turn the key ON. Its not much of a problem, more annoying than anything, but sometimes it takes anywhere from 2-5 minutes. Any ideas?
Re-soldered it. It seems to have done the trick. It still takes a few seconds, but seconds beats minutes, and its not like I was going to use it as a getaway car any time soon.
