Funny Reverse Noise
Old Aug 4, 2004 | 12:01 PM
H.crx-si
Guest
Posts: n/a
Default Funny Reverse Noise
When I throw my car into reverse and start backing up I get a funny sound like gears inside the tranny are rubbing. This only happens in reverse any ideas how to make it go away without overhauling the tranny.....maybe a little lucas transmission fix?
Old Aug 4, 2004 | 01:08 PM
gsrtxjarrod's Avatar
Default Re: Funny Reverse Noise (H.crx-si)
The reason is because ur reverse gear is a straight tooth design much like that of nascar which is the reason it so loud. Also reverse is the only straight design so no i wouldn't worry about a overhaul it would sound the same when ur done
Old Aug 4, 2004 | 01:12 PM
Keno20's Avatar
I 2 have this problem, a mechanic friend of mine suggested that my gearbox oil was running low but when i checked it it was sweet as.
I dont know if its anything to major as my gearbox has only recently been pulled apart by a gearbox specialist (i siezed the bush in reverse doing reverse donuts) and he never found anything else wrong in that department. (my reverse was makn the noise before doin the donuts by the way)
Old Aug 4, 2004 | 01:13 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Funny Reverse Noise (Keno20)
all manuals with a straight reverse gear do that.
Old Aug 4, 2004 | 01:38 PM
smemts's Avatar
Default Re: Funny Reverse Noise (dLo GS-RaArRrRrRRRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GS-RaArRrRrRRRR &raquo;</TD></TR><TR><TD CLASS="quote">all manuals with a straight reverse gear do that.</TD></TR></TABLE>
Old Aug 4, 2004 | 01:39 PM
Keno20's Avatar
I dont know about "H.crx-si" but im not talking about a faint noise, this is a big *** noise which definitly aint normal,.
Old Aug 4, 2004 | 01:51 PM
H.crx-si
Guest
Posts: n/a
Same here no faint noises at all its a loud tinny noise. Last night it was about as loud as when your powersteering belt lets out a loud squeal.
Old Aug 4, 2004 | 06:01 PM
Default Re: (H.crx-si)
yes, that is what it sounds like. listen to any manual car go in reverse.
Old Aug 4, 2004 | 06:14 PM
H.crx-si
Guest
Posts: n/a
OHHH I get it, so every manual car going into reverse sounds like a dozen metal forks in a blender? I think not...... something is definatly wrong and the sound dosn't simply happen when I switch into the gear the sound happens as I back up as well. Sounds similar to when I had a loose cat. heat shield on my crx except inside the tranny this time around.
Old Aug 4, 2004 | 06:30 PM
3.504's Avatar
the only way reverse is bad is if there is a wine in all gears that increases pitch with speed. thats the reverse idler wearing. reverse should make a loud winey sound and increase pitch and possibly volumn with increased speed. reverse is a spur cutter just like stated before thats why it wines. the other gears (all of them) are helical cut and damn near silent + stronger.... its a pretty neat design but i wont go into it... but thats the reason the others are silent. also reverse is not syncronized, so thats why you clash a little sometimes going into reverse even on a brand new tranny. reverse actually pushes a gear into another gear, it doesn't slide a sleeve over clutching teeth that have a brass blocking ring in between to act as a friction material to equalize sleeve/gear speed.
hopefully that explains any sounds you're getting from reverse gear.
Old Aug 4, 2004 | 06:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si &raquo;</TD></TR><TR><TD CLASS="quote">OHHH I get it, so every manual car going into reverse sounds like a dozen metal forks in a blender? I think not...... something is definatly wrong and the sound dosn't simply happen when I switch into the gear the sound happens as I back up as well. Sounds similar to when I had a loose cat. heat shield on my crx except inside the tranny this time around.</TD></TR></TABLE>
YES, that is the EXACT ******* sound.
Old Aug 4, 2004 | 07:26 PM
H.crx-si
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">YES, that is the EXACT ******* sound.
Tool
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the only way reverse is bad is if there is a wine in all gears that increases pitch with speed. thats the reverse idler wearing. reverse should make a loud winey sound and increase pitch and possibly volumn with increased speed. reverse is a spur cutter just like stated before thats why it wines. the other gears (all of them) are helical cut and damn near silent + stronger.... its a pretty neat design but i wont go into it... but thats the reason the others are silent. also reverse is not syncronized, so thats why you clash a little sometimes going into reverse even on a brand new tranny. reverse actually pushes a gear into another gear, it doesn't slide a sleeve over clutching teeth that have a brass blocking ring in between to act as a friction material to equalize sleeve/gear speed.
hopefully that explains any sounds you're getting from reverse gear.</TD></TR></TABLE>
I've been driving standard tranny cars for 6 years and I know the winey sound on every manual tranny car this isn't the first time I've used reverse. That isn't the sound I'm speaking of, nor is the sound as reverse is engaged. The release bearing is going in the car and can be heard in all gears however when in reverse the sound I hear is horrible and not normal, it happens as the car is in motion and it has a tinny clanking broken sound. Its not the normal reverse squeal that is always heard it sounds like metal gears grinding together and broken peices of metal inside the tranny. I'm thinking nobody has the answer here so I'll just have to pull the tranny and have a look for myself. Thanks for trying though.
Old Aug 4, 2004 | 07:49 PM
tommymoose's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">reverse is not syncronized, so thats why you clash a little sometimes going into reverse even on a brand new tranny. reverse actually pushes a gear into another gear, it doesn't slide a sleeve over clutching teeth that have a brass blocking ring in between to act as a friction material to equalize sleeve/gear speed.</TD></TR></TABLE>
THATS WHY?.... thanks for that brief explination. I always wondered why I couldn't put my cars (all hondas) into reverse while the car was still moving forward slowly even though I have the clutch down.
Old Aug 4, 2004 | 08:01 PM
Keno20's Avatar
Let me know how you get on when you pull it out, cos unlike other people I know that there is something going on that aint normal.
Old Aug 5, 2004 | 01:03 PM
3.504's Avatar
Default Re: (Keno20)
if you have some clanking of metal... theres some chunked gear teeth. change oil and get the metal out ASAP so you dont ruin anything else.
Ashliegh101
Honda Civic (2001 - 2005)
Jul 27, 2013 10:01 AM
vtec6200
May 16, 2008 03:15 PM
FlatlineSI28
Honda Civic (2006 - 2015)
19
Feb 17, 2008 09:45 AM
cvstrat
Oct 27, 2003 10:01 AM
JDEM1
Aug 4, 2003 08:24 PM
