Frozen Control Arm bolts
Old 02-23-2003, 06:42 PM
conesmasher's Avatar
Default Frozen Control Arm bolts
It's a typical honda kinda thing. But does anyone know how much? the rear lower control arm bolts are that freeze up??????
Old 02-23-2003, 06:46 PM
blacks2000's Avatar
Default Re: Frozen Control Arm bolts (snoballgsr)
Does anyone know how much what? How much they cost to replace? or get pressed out? I don't get your question.
Old 02-23-2003, 06:50 PM
Default Re: Frozen Control Arm bolts (blacks2000)
How much the bolts are to replace in parts terms. Just looking for a price on the bolts themselves, no labor.
Old 02-24-2003, 08:34 AM
is anyone out there I know that you guys have replace these before, it is notorious on hondas
Old 02-24-2003, 08:41 AM
Eva01's Avatar
Shouldn't be more than a couple of bucks. At acuraautomotiveparts.org, their pic is down for rear lower control arm but I think the bolts cost around 3.50 a piece at the dealer. I did my suspension install this week and luckily my bolts weren't frozen. And this was for a 94. Looks like someone had put some antiseize on them before thank god.
Old 02-24-2003, 09:15 AM
Trac226's Avatar
Default Re: Frozen Control Arm bolts (Eva01)
Try some rust penetrant and a breaker bar. Hmmm, I think I will try and start an impact wrench movement here on h-t...it doesn't cost that much and is darn worth it.
Old 02-24-2003, 01:03 PM
basmasta7's Avatar
Default Re: Frozen Control Arm bolts (Trac226)
you'll be spending a lot of money if the heads on the bolts bust off. i learned the hard way... you're either gonna have to get a shop to put in new bushings in the LCAs or get new LCAs all together.
Old 02-24-2003, 02:26 PM
miketegra's Avatar
Yeah, try some penetrant and let it soak for a while.
Once you get air tools, you never go back !
My air wrench took off the dreaded crankshaft pully bolt in about .25 seconds once I took the socket extension off.
Old 02-24-2003, 02:58 PM
Scary1109's Avatar
exactly, use an impact gun and penetrant. that's what i did, then use anit-seize.
Scary
Old 02-24-2003, 03:15 PM
blacks2000's Avatar
Default Re: Frozen Control Arm bolts (Scary1109)
THe heads broke off of mine. The bushings are like 28 bucks each and the bolts are like 7 I think. You'll need a shop to press them out unless you wanna do it the ghetto way like I did. Get a blow torch, and get it icy hot like some of the stunna around here. Then pound it out with a hammer.
Old 03-20-2003, 09:58 AM
kay_animation's Avatar
Well, the bolt snapped on both mine. One we drilled out. It took 6 hours. The other one, I think i'm just going to give up on salvaging the old control arms and just buy new ones. I got a hook up on drilling them out but they said that it would normally cost like 200 dollars. Thats like the cost of some ssr control arms. Thats crazy.
Old 03-20-2003, 11:36 AM
Xscream's Avatar
Default Re: Frozen Control Arm bolts (kay_animation)
I've snapped plenty of them... When you put the new ones back in use anti-seeze and TQ to SPEC and you will never have the problem again.
speedpro92
12-22-2010 08:17 AM
BoostinEJ1
36
06-10-2004 10:54 AM
monotone485
10-21-2003 02:00 PM
Quick Reply: Frozen Control Arm bolts
