Figuring out engines
Old Dec 1, 2002 | 12:05 AM
The new guy's Avatar
Default Figuring out engines
I know the GSR engine has more power then the LS but why? is it because of a different design or because it has certain performance factory parts that can easily be added onto a LS?
Old Dec 1, 2002 | 12:10 AM
xteg95's Avatar
Default Re: Figuring out engines (The new guy)
vtec...
Old Dec 1, 2002 | 02:24 AM
97hb's Avatar
Ones bigger than the other , yet are both 1.8's.
Old Dec 1, 2002 | 05:23 AM
gsr96's Avatar
A gsr has vtec, which is variable valve timing and lift electronic control. It is made up of another lobe on the camshafts and do just what the name says, varies the valve timing at high rpm's to maintain a nice smooth torque and power curve. The also have a higher compression ratio than an LS and are geared better, which makes them faster.
Old Dec 2, 2002 | 12:54 AM
NuclearB18B's Avatar
Default Re: Figuring out engines (97hb)
vtec motor has less displacement than non vtec
lilxchris
12
Mar 27, 2009 05:44 PM
BEATurBOYS
Jan 12, 2009 05:33 AM
crixer340
Aug 14, 2006 04:01 PM
DsBananas94LS
Dec 26, 2004 09:56 PM
AllMotorRP
Feb 18, 2004 04:04 PM
