Failed emissions-check engine light on- code P0420
Old Oct 21, 2005 | 07:30 PM
crf450ex's Avatar
Default Failed emissions-check engine light on- code P0420
Allright, i just bought a 98 gsr out of state in order to register it i had to get emissions checked. I failed. The code he gave me was P0420 Catalyst System Efficiency Below Threshold. Now how should i go about fixing this. I have hp racing headers, a jackson racing 2.5 " cat, and comptech catback. The car seems to run fine, just smelling the exhaust it smells a little rich but im not saying it is for sure. The car runs and idles fine, good throttle response, low end power is a little weak, but then again this is my first 4cyl. Topend is real strong, i would never guess anything was wrong with it.
The code that the shop gave me was P0420 Catalyst System Efficiency Below Threshold
The guy before me pulled the check engine light bulb. Now do u think this is a cat problem? Maby its not functioning proberly? Or do u think one of the O2 sensors went bad? How can i find out? And were should i get the sensor and the cat for the best price? Thanks, Ryan
Old Oct 21, 2005 | 07:32 PM
shady visions's Avatar
Default Re: Failed emissions-check engine light on- code P0420 (crf450ex)
Advanced auto for the O2 sensor. It should run you ~40$ for the non-universal one (recommended). Putting it in shouldn't be a problem since you don't have a stock manifold. I don't know about the room in integras, but stock exaust manifolds in CRXs leave no room in the CRX engine bay to change the sensor.
Old Oct 21, 2005 | 07:36 PM
crf450ex's Avatar
Default Re: Failed emissions-check engine light on- code P0420 (shady visions)
So which o2 sensor do i need the pre cat? Or the after cat?
Old Oct 22, 2005 | 02:53 PM
crf450ex's Avatar
Does anybody know?
Old Oct 22, 2005 | 03:33 PM
non-VTEC's Avatar
you need to put a new CAT or the OEM CAT back on and have it re-tested. the code they gave you is telling you the CAT is below its threshold.......meaning it not working properly.
Old Oct 22, 2005 | 03:34 PM
92integraVTECgsr's Avatar
Default Re: Failed emissions-check engine light on- code P0420 (cnaman)
yes. first of all, put the bulb back in so you can find out what is wrong.. then you can check the code..
if anything.. seafoam the engine through the brake booster line. my friend failed his emissions big time last week, i seafoamed it.. passed with FLYING COLORS.
and I just tested mine yesterday and past with flying colors too.. SeaFoam works!!!!
put half a bottle in your gas tank before you fill up, and through the brake booster line, then if you need to change your O2 Senor(s) you'll pass easily.
Old Oct 22, 2005 | 08:33 PM
smkngsr's Avatar
Default Re: Failed emissions-check engine light on- code P0420 (92integraVTECgsr)
thats the code...hope that helps u somehow
Old Oct 22, 2005 | 08:37 PM
crf450ex's Avatar
but that code wouldnt be given, if cat was working, but one of the O2 sensors was shot? Its definatly the Cat? Do oversized cats usually fail emissions?
Does anyone have a stock cat they could sell me, or know where i could get one.
Old Oct 27, 2005 | 01:52 PM
acuramike's Avatar
po420 is a bad catalytic converter
xprohx
Jul 29, 2008 12:03 PM
Bonestock98GS
Sep 5, 2006 07:46 AM
gsrhunny
Jul 9, 2002 04:56 AM
onyx00
Apr 20, 2002 12:32 PM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
