Need help fixing code 61 and 67
Old Jul 29, 2008 | 08:52 AM
xprohx's Avatar
I think too much
Default Need help fixing code 61 and 67
I have been driving with my check engine light on for awhile now and finally decided to check to see what the problem was. After checking it was error code 61 (Primary Oxygen Sensor) and code 67 (Catalyst low efficiency).
Would a simple replacement of the O2 sensor and Catalytic converter solve my problem?
Old Jul 29, 2008 | 10:15 AM
90lsteg's Avatar
Default Re: Need help fixing code 61 and 67 (xprohx)
Generally, yes. Most times a Honda has a Catalyst below efficiency threshold code it needs a cat. Check the wiring for the o2, but it probably needs to be replaced as well.
Old Jul 29, 2008 | 12:03 PM
xprohx's Avatar
I think too much
Default Re: Need help fixing code 61 and 67 (90lsteg)
The catalytic converter is a 2.5" Hi Flow cat purchased from IPS racing (I believe). It is about 4 years old now.
Where can I get another hi-flow cat that is a direct bolt on for my 2000 gsr?
chad.bawden
Apr 18, 2010 09:45 AM
Bozo_JDM
Nov 20, 2008 08:21 PM
btrim23
Mar 14, 2005 08:01 AM
Another_Teg_Owner
Dec 15, 2003 11:11 PM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
