check engine light (code 67)
Old Jul 7, 2002 | 04:44 PM
gsrhunny's Avatar
Default check engine light (code 67)
my check engine light keeps coming on and its giving code 67 which is "Catalyst System – Efficiency below threshold. Malfunctioning, missing, or defective catalyst system". how can i fix this? the car runs like **** when the light is on. thank you.
Old Jul 7, 2002 | 05:17 PM
Tanner's Avatar
New User
Default Re: check engine light (gsrhunny)
Hmm I am guessing your catalytic converter is shot.. but with it running bad maybe an O2 sensor... I would go to the dealer and have them run a diagnostics on it and let you know..
Old Jul 7, 2002 | 05:25 PM
gsrhunny's Avatar
Default Re: check engine light (Tanner)
thank you. i just replaced the o2 sensors. i guess i'll just get my high flow cat and 3" exhaust now.
Old Jul 7, 2002 | 05:28 PM
Tanner's Avatar
New User
YEah thats the best way to do it!!!
Old Jul 7, 2002 | 05:39 PM
Tired's Avatar
if its broken, upgrade it
Old Jul 7, 2002 | 05:51 PM
Audi A4's Avatar
Default Re: check engine light (Tired)
how much u pay for taht o2
Old Jul 8, 2002 | 10:05 AM
Comptech98GSR's Avatar
Default Re: check engine light (DRAG lll INTEGRA)
too much octane booster, or race gas, will also burn up the cat, or if the gas has lead in it.....mine burnt up once, got it replaced under warranty though
Old Jul 8, 2002 | 10:55 AM
LillDragun's Avatar
what year teg do you have....i have the same problem. when i got my exhaust in may it started thowing me the code 67. what kind of o2 sensors did you get and how much were they. did you <U>have to</U> replace both of them? did the light come back on after you reset the ecu?
Old Jul 9, 2002 | 04:56 AM
gsrhunny's Avatar
Default Re: check engine light (LillDragun)
its a 2000 gsr with turbo. i replaced the sensors with stock ones. the primary sensor cost me $200 and the secondary was $160. i replaced the primary sensor about a month ago because i was getting code 1. then last week i started getting code 67, i was told it was the secondary sensor, so i replaced that on saturday. while driving my car on sunday nite and this morning the stupid check engine light came back on, again code 67. so now i have to replace the cat. if its not one thing its another.
00accord00se
Jul 22, 2013 08:23 PM
dashskier540
May 21, 2006 06:39 PM
mr0lg
Dec 9, 2005 06:19 PM
brad98_teg
Mar 28, 2005 06:17 AM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
