Engine Replacement
Old Aug 21, 2006 | 03:42 PM
purangboy's Avatar
Default Engine Replacement
I need to replace my engine and tranny in my 96 ls 4dr 5 speed. I have been looking at b18b1 engines and I see alot of OBD I II's for sale, the only difference I have been able to tell is the valve cover, I am pretty sure mine is OBD II, would there be any difference between the two in my car for a replacement, is there any difference other than the valve cover?
Thanks
Old Aug 21, 2006 | 03:54 PM
purangboy's Avatar
anyone?
Old Aug 21, 2006 | 04:01 PM
DC2 Mang's Avatar
Default Re: Engine Replacement (purangboy)
they are the same motor, the obd2 just have no oil seperator on the back of the block
you can use either motor, just use your odb2 distributor, ecu, wire harness and possibly oil pump if it has the crank position sensor on the obd1 block
Old Aug 22, 2006 | 07:14 PM
GoldCoin's Avatar
Default Re: Engine Replacement (DC2 Mang)
id go obd1 just cuz obd2 got way to many restrictions
Old Aug 22, 2006 | 11:20 PM
DC2 Mang's Avatar
Default Re: Engine Replacement (DC TWOin IT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC TWOin IT &raquo;</TD></TR><TR><TD CLASS="quote">id go obd1 just cuz obd2 got way to many restrictions</TD></TR></TABLE>
because of the ecu, not the motor, I had an obd2 ls motor is my 95 obd1 integra, its the same motor just the ecu for obd2 has quite a few more sensors and diagnostic tools in the ecu
Old Aug 23, 2006 | 02:11 PM
GoldCoin's Avatar
dam good . haha. ecu is what i meant. i have a ecu jumper where i can use obd1 on obd2 cars. very useful for my friend. runs a poormans itr with p28chip in a ek
Old Aug 23, 2006 | 02:18 PM
XYU's Avatar
XYU
Ask me about vaginal warts
I would get B20B with same OBD ----- more torque
Modified by red eye teggy at 6:55 PM 8/23/2006
Old Aug 23, 2006 | 05:15 PM
GoldCoin's Avatar
Default Re: Engine Replacement (red eye teggy)
i think i would go b20 also . long block .
diviznrider
13
Apr 19, 2019 01:38 PM
Jhonny Ricer
May 28, 2007 12:02 AM
blackeg
Oct 12, 2004 03:12 AM
Ehron
Sep 22, 2002 09:51 PM
