Engine Problems
Old Aug 25, 2004 | 09:08 PM
BDBGoalie1982's Avatar
Default Engine Problems
Hello all,
I was driving down a country road, fast, but not terribly fast, shifted into fourth and the engine dropped into neutral, and overreved, and stalled. The engine then would not start, but was truning over. The colant level was a little low int eh radiator and smelled burnt. The engine bay smelled a bit of burnt colant. No fluid leaks of any kind. Spark plugs were not oily (top side only, did not have tools to remove) or colant coated. I removed teh plug wires and ecu fuse and the car made the same sounds as before (with wires attached), turning over, but no ignition, leading me to belive i spun my distributor, shaft or contact point.
Any opinions or comments are welcome, need some other perspective.
-Thanks
Old Aug 25, 2004 | 09:11 PM
luvinmyGSR's Avatar
Default Re: Engine Problems (BDBGoalie1982)
got me, hope u get things worked out
Old Aug 26, 2004 | 05:00 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDBGoalie1982 &raquo;</TD></TR><TR><TD CLASS="quote">... I removed teh plug wires and ecu fuse and the car made the same sounds as before (with wires attached), turning over, but no ignition...</TD></TR></TABLE>Of course there's no ignition when the ecu fuse is pulled...
Do you have spark (with the fuse back in)? Do you have fuel?
Old Aug 26, 2004 | 12:58 PM
Default Re: Engine Problems (JimBlake)
writing the no igition was just stupid, excuse that.
Went to acura today and they think its a bent valve, remaining sealed, and not letting the engine fire. My frind has my compression tester so when that arrives, i wil go find out for sure.
Old Aug 26, 2004 | 01:12 PM
Googs16's Avatar
Does it crank normal when you try to start it?
Check your timing belt, it might have spun,
A friend of mine just spun his belt and bent the a couple valves
Old Aug 26, 2004 | 08:48 PM
Default Re: Engine Problems (Googs16)
Bent all valves.
75 0 0 ? compression
? is because the heat melted and fused teh spark plug into the housing, and shrapnelized everything. \
Getting the head off sat to find out damages
Old Aug 26, 2004 | 11:12 PM
sPaRk'iT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDBGoalie1982 &raquo;</TD></TR><TR><TD CLASS="quote">Bent all valves.
Getting the head off sat to find out damages</TD></TR></TABLE>
Keep us updated!
Old Aug 28, 2004 | 07:29 PM
Default Re: Engine Problems (sPaRk'iT)
Head is gone.
4 is scratched to hell, and the piston has a hole in it the size of a silver dollar. you can see the entire connecting rod joint.
So i need a new head, and proble will get the block sleeved to fit CTR pistons (.25 over).
Anyone who knows good resourses for this will be very helpful
I've heard good things about Gude heads.
Machine shop is probley already taken care of depending on cost.
I need some good lines on CTR pistons though.
Pics tommorow
Thanks
Old Aug 28, 2004 | 11:22 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDBGoalie1982 &raquo;</TD></TR><TR><TD CLASS="quote">Head is gone.
Pics tommorow
Thanks</TD></TR></TABLE>
accidentally shifted into 2nd instead of 4th man? overreved? (sound like shifted in the wrong gears with driving fast (100mph) it should killed ur head easily
well anyway sorry to hear that ....goodluck on ur way
prelude_93vtec
Jul 17, 2007 01:48 PM
stevescivic
Jul 26, 2004 07:06 PM
Deluzional
Oct 24, 2003 09:50 AM
2camsaam
Oct 5, 2002 10:07 AM
