Engine mounts are toast... replace: OE or Poly?
Old Oct 23, 2008 | 08:59 AM
intgrboy's Avatar
Default Engine mounts are toast... replace: OE or Poly?
Just picked up a '94 Integra and it seems to be jarring between shifts - and visually i know one of the mounts is done for.
This is just a daily driver, pretty much stock - will be droppin it about 1.5" soon. What is my best, cost effective option for replacing the mounts? OE? Poly?
and how hard is it to buy the inserts and do that install?
thanks.
Old Oct 23, 2008 | 09:24 AM
Kendall's Avatar
The inserts are way cheap, rather effective, and install easily if you have any idea what you're doing. What you need to note is that the inserts are for the rear mount and lower mounts only, nothing for the uppers. Also note that the inserts are intended to be used with healthy OEM mounts as something to reduce engine movement, not as a band-aid for worn out stock mounts. Inserts will also compromise the ride quality to some extent.
My advice is to pursue new OEM mounts.
Old Oct 23, 2008 | 10:00 AM
shortycm17's Avatar
Default Re: (Kendall)
depending on what stiffness insert you get the engine vibration will increase from stock... i.e your dash may rattle and things may shake if you go with a stiffer insert ...
Old Oct 23, 2008 | 10:18 AM
ruffrhyder's Avatar
Default Re: Engine mounts are toast... replace: OE or Poly? (intgrboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intgrboy &raquo;</TD></TR><TR><TD CLASS="quote">Just picked up a '94 Integra and it seems to be jarring between shifts - and visually i know one of the mounts is done for.
thanks.</TD></TR></TABLE>
Go to OSH and buy a $6 tube of polyurethane and DIY
clem kevin
May 1, 2008 06:57 PM
92 CIVIC HATCH VX
Nov 11, 2005 10:28 AM
vangc6780
May 1, 2005 10:14 PM
Prolink
Jan 12, 2005 06:01 PM
Drew Peacock
Dec 3, 2004 03:31 PM
