Engine Compression Test
Old Feb 15, 2005 | 03:34 PM
  #26
95lstegman's Avatar
Default Re: Engine Compression Test (vgsr)
compression range is 140-270psig, variation is 28psig max. Good numbers, however, would be close to 200psig or above and within 5psi of each, 10psi max. if there is >10psi difference, you've got a problem. variation is more important than overall maximum pressures.
Old May 20, 2005 | 03:17 PM
  #27
BLUE EH3's Avatar
Help we my pennies
Default Re: Engine Compression Test (95lstegman)
what do the c0mpression number mean?
Old May 20, 2005 | 09:35 PM
  #28
elrandeeto's Avatar
my 90 ls was 150 on all 4 do i need a rebuild
Old May 21, 2005 | 06:09 AM
  #29
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: (Tampa94lsteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tampa94lsteg &raquo;</TD></TR><TR><TD CLASS="quote">BTW:....crank it over 7 times..</TD></TR></TABLE>
crank it over 3 times, the third time is what you record; it should be about twice as high as the first stroke.
Old May 21, 2005 | 06:11 AM
  #30
Default Re: Engine Compression Test (peel17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peel17 &raquo;</TD></TR><TR><TD CLASS="quote">Bump.. anyone else have comments?</TD></TR></TABLE>
mine were all at 149-151, with 125k, so yours is fine. stop worrying about it, theres nothing wrong with your engine as far as a compression test goes.
Type 56
Oct 12, 2016 11:10 AM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
John.
Jun 12, 2006 08:45 AM
blackeg
Mar 28, 2005 06:10 AM
mafay2
Nov 11, 2004 07:34 PM
