Engine Compression Test
Old Feb 9, 2005 | 11:27 AM
peel17's Avatar
Default Engine Compression Test
I'm having my 2000 LS motor go through a compression test. What would be the numbers for each cylinder?
here are my results.. what you guys think? The reason why i did a compression check was because the car is losing about 1 quart of oil a week about 260 miles of driveing a week. What is causing my car to lose oil. just a couple drops from my the oil pan screw, nothing serious. car is not blowing out blue or black smoke?
2000 ls motor w/45k
#1 - 170
#2 - 175
#3 - 170
#4 - 185
Modified by peel17 at 12:18 PM 2/11/2005
Modified by peel17 at 12:51 PM 2/11/2005
Kowalski's Avatar
Default Re: Engine Compression Test (peel17)
Around 200 within 10% of each other is always good...
Old Feb 9, 2005 | 01:19 PM
95lstegman's Avatar
Default Re: Engine Compression Test (Kowalski)
170psi is good. 200psi is basically new. all cylinders need to be within 28psi of each other. that means the highest needs to be no more than 28psi over the lowest, but even if it's this much you should be worried. variation shouldn't be more than 10psi or so on a healthy motor. <140psi is defined as "in need of rebuild, like, yesterday." i'd expect about 180psi out of a 2000 car, but i don't know how many miles or how nice its life has been, so it's just a WAG (wild @$$ guess).
Old Feb 9, 2005 | 06:15 PM
Punkinterviews's Avatar
I had a 97 LS swapped into a 90 DA and it made 210 across the board :D
Old Feb 9, 2005 | 06:28 PM
SOHCD16y8's Avatar
175-200 and your fine
Old Feb 9, 2005 | 06:46 PM
95lstegman's Avatar
Default Re: (Punkinterviews)
wow. 210 is nice. how many times did you crank it over?
Old Feb 11, 2005 | 08:31 AM
peel17's Avatar
Default Re: (95lstegman)
her are my results.. what you guys think?
2000 ls motor w/45k
#1 - 170
#2 - 175
#3 - 170
#4 - 185
Old Feb 11, 2005 | 09:06 AM
Tampa94lsteg's Avatar
Default Re: (peel17)
nice low compression! turbo that bitch!
Old Feb 11, 2005 | 09:07 AM
Default Re: (Tampa94lsteg)
BTW:....crank it over 7 times..
Old Feb 11, 2005 | 09:26 AM
peel17's Avatar
i'll probably pass on modifications. its my commuter car
BTW: its a 92 DA with a 2000 LS motor
Old Feb 11, 2005 | 11:19 AM
peel17's Avatar
is that good #'s?
Old Feb 11, 2005 | 11:29 AM
Buktheng's Avatar
Where did u go to get a compression test?
Old Feb 11, 2005 | 11:37 AM
peel17's Avatar
Default Re: (Khoifather)
got it for free at AAMCO while i was getting my tranny checked
Old Feb 11, 2005 | 12:45 PM
peel17's Avatar
2000 ls motor w/45k
#1 - 170
#2 - 175
#3 - 170
#4 - 185
Kowalski's Avatar
Nice numbers.
I had about 185 across the board on my 96 with 110k
Old Feb 11, 2005 | 01:38 PM
vtec69's Avatar
not great but not bad at all for an LS
Old Feb 14, 2005 | 02:12 PM
peel17's Avatar
Bump.. anyone else have comments?
Old Feb 14, 2005 | 02:23 PM
95lstegman's Avatar
you're leaking the oil if it's not smoking white/blue-ish. a quart a week is a heck of a lot of oil, my friend. check the cam seal (exhaust cam, on engine on the passenger's side and towards the front of the vehicle), check the oil pan gasket, the valve cover gasket, and, of course, the nut (although not likely). clean the area to be checked very thoroughly, so that it looks like new. then drive to the store or something, come back, open the hood, and see where fresh oil has sprouted. then fix the leak.
Old Feb 14, 2005 | 07:52 PM
gen2integra2001's Avatar
Default Re: Engine Compression Test (95lstegman)
NOT TO STEAL YOUR THREAD
i was wondering if my compression test was good for my 91 ls engine with over 220k on it 190..180..180..185 im going to boost in a week or so and was wondering if this was good numbers for a 14 yr old engine
Old Feb 15, 2005 | 08:23 AM
95lstegman's Avatar
Default Re: Engine Compression Test (gen2integra2001)
yeah, the numbers are great for an old engine. they're phenominal, in fact. but compression test is not the end-all be-all to tell if you can boost. it's encouragement, but i would NEVER boost on an engine maybe half that old. i just don't like to take the chance, you know? you might get away with it for a few years, but i seriously doubt it. after that long, your engine is just worn all over. at minimum, i would hone and rering the engine, replace main and rod bearings, and replace oil pump. also adjust the valves; hell, why not? maybe at 100k miles, with those numbers, and a '98 engine, then yes. but at least i'll be good and not encourage you to do it. i would hate to see you f* yourself on my advice.
Old Feb 15, 2005 | 08:27 AM
DSPDA3's Avatar
On a similar note - I tested recently at
1 - 195
2 - 200
3 - 205
4 - 195
184k miles on the clock. Leaks about 1qt. oil every oil change, no sign of burning oil.
Old Feb 15, 2005 | 08:33 AM
95lstegman's Avatar
Default Re: Engine Compression Test (DSPDA3)
wow dudes. how many times do you crank it over when you compression test? do you just do it until the pressure won't go any higher?
Old Feb 15, 2005 | 01:37 PM
on mine i did like about 6-7 cranks...oh the ehead is a port n polish b18a head with 404 cams, dual valve springs, SS valves and completely stock block that burns 1qt of oil in about 9-12 days at high rpms... i already have a set of rods n pistons for a new block that im looking for... and i wont be running tha **** outta this engine with the turbo kit on it....just gonna take it nice n easy so i can break in the turbo
Old Feb 15, 2005 | 02:00 PM
95lstegman's Avatar
wow. you got hella good compression then. you're lucky. but i don't think compression is everything, but it is nice . . .
Old Feb 15, 2005 | 03:21 PM
vgsr's Avatar
NOT to steal this thread,
What would be some good compression numbers for a 2000 GSR w/ about 123k highway miles?
What is the compression range for a brand new 00' GSR?
