Engine buildup question.
Old Jul 30, 2002 | 09:35 AM
Four Door LS VTEC's Avatar
Default Engine buildup question.
I have a Integra LS, the block has @130,000 miles on it. I have JE pistons (standard bore) and rods that i am going to have installed.
My question is should my block be ok for the pistons, or should I either find a low mileage LS block or have the sleeves redone.
If you guys recommend having the sleeves redone, what would the parts cost and how difficult is it to do?
[Modified by Four Door LS VTEC, 2:02 PM 7/30/2002]
Old Jul 30, 2002 | 09:54 AM
GM2000ITR's Avatar
New User
Default Re: Engine buildup question. (Four Door LS VTEC)
You should be fine as long as you take the necessary steps to build your motor, such as: all new bearings & seals, new oil & water pump, get slugs honed(at very least) and last, but DEFININTELY NOT LEAST, get ARP rod bolts! OEM rod bolts can lick the sweat off my sack! They are low grade steel and will stretch under high RPM (ask me how I know)causing all things bad! Good Luck!
Old Jul 30, 2002 | 04:33 PM
Default Re: Engine buildup question. (GM2000ITR)
thanks for the info...luckily the eagle rods come with ARP bolts...so its gravy.
Old Jul 30, 2002 | 04:54 PM
GM2000ITR's Avatar
New User
Perfect!
Old Jul 30, 2002 | 09:03 PM
vhd's Avatar
vhd
you should of went with oversize piston, ethier .010" or .020" over. with the block having 130,000+ miles, the cylinders will most likely be out of round and tapered. this will gurantee a perfectly round and straight cyl to properly seat the rings. a deglazed won't be a good idea with the new piston rings cause of the amount of miles and will cause access amounts of blow-by
Old Jul 31, 2002 | 05:26 AM
GM2000ITR's Avatar
New User
Default Re: Engine buildup question. (vhd)
WTF is this guy saying?!?!?!?!??????
Old Jul 31, 2002 | 06:35 AM
slickboy's Avatar
New User
He is saying that with a block with some age on it, you really shouldn't just slap new pistons in there without at least getting the cylinder walls honed, and it would be a very safe idea to get the block overbored to like .020" over the standard bore. Basically they drill(bore) the cylinder walls out larger than they were stock to give a fresh mating surface between the new rings and cylinder walls. You don't want to chance not at least honing the walls when you put in new pistons. They might not seat right and then you've just wasted time and money. I've seen a motor been rebuilt that the cylinder walls were never touched during the rebuild process and the piston rings glazed at he was SOL and out about $1000. While you're at it, have the block hot tanked to get it cleaned up...you'll be glad you did.
[Modified by slickboy, 3:37 PM 7/31/2002]
shoebox
Sep 27, 2006 08:34 AM
caspers_hatch
Dec 18, 2005 07:51 AM
r3v da t3g
Mar 26, 2005 08:06 AM
slayersluck
Dec 6, 2004 11:01 AM
GRIMEY.STREET.RACER
Jan 6, 2003 06:00 AM
