electrical problems with recent swap
Old May 19, 2006 | 04:22 AM
god.loves.ugly
Guest
Posts: n/a
Default electrical problems with recent swap
I just swapped b18c1(obd1) into my LS integra. I have everything connected with the exception of the knock sensor. and that is the only CEL I am throwing. but my Tach won't go past 5k once it hits 5k it goes crazy, I've checked all the grounds and wiring to the distributor I cannot find any problems there, and also today for some reason my wipers just turned on... switch was on "off" so I have no idea how that happened but then they wouldn't turn off. I turned my car off then back on and they worked fine. with the switch.
Any suggestions would be great.
Old May 19, 2006 | 06:33 AM
DC2 Mang's Avatar
Default Re: electrical problems with recent swap (so.dark.the.con.of.man)
what year ecu and cluster are you using?
usually you have to match the two with the same ODB version
Canadian_EF
15
Nov 1, 2012 10:24 PM
90ED6LSV
Feb 3, 2012 09:01 AM
IOwNaHoNdA
Nov 16, 2010 10:39 AM
95lscivic
13
Nov 4, 2008 11:19 AM
bluesjones
Nov 4, 2002 11:11 AM
