ELECTRICAL EHHHHHH!!!!
Old May 24, 2011 | 03:57 PM
shelltodreamda9's Avatar
Icon2 ELECTRICAL EHHHHHH!!!!
HEY PEEPS .. FIRST OFF I JUST WANT TO THANK EVERYONE
WHO HAS HELPED IN THE PASTED. AS WELL AS THE SITE HAS BEEN A GOOD RESOURCE ... SO NOW THATS ALL DONE..
I GOT A DA SHELL THAT WAS IN A FIRE AND IT LOOKS LIKE THEY CUT THE WIRE HARNESS...
HOW DO INSTALL A NEW ONE ...
AND WHICH WIREHARNSS HAS THE PLUGS FOR THE HEAD LIGHJTS AND
BUMPER LIGHTS...
AND IS THERE ANY SO-CAL MEMBERS.
NEAR FONTANA THAT DOES ELECTRICAL..
Old May 24, 2011 | 04:28 PM
Tha_liks's Avatar
Default Re: ELECTRICAL EHHHHHH!!!!
if its in the engine bay .. you will have 2 harness, one is the harness for all the components under the hood, the other is the Engine harness... if it was in a fire.. i suggest you go to a junk yard and see if you can find a donor car to pull the complete harness for you to use, or
This is just for the Motor Harness..
http://cgi.ebay.com/ebaymotors/90-93...Q5fAccessories
Old May 25, 2011 | 03:35 PM
do both the wire harness run into the fuse box under the steering wheel area??
wish the previsious owner of the car didnt leave it all messy crazy wires and exposed spekers ends ... effff,,,
all in all its a good project ... shes gonna be a beast.......
Old May 25, 2011 | 03:44 PM
Tha_liks's Avatar
NO, you have a motor harness, an interior harness, and the main harness, You can Also go to a salvage yard and try and find an integra and cut the harness from where yours is cut, and resolder all the wires by matching the colors up.
But you risk it coming loose or breaking, if you do it that way make sure you welds are solid and you secure it hard to they wont come loose
Old May 25, 2011 | 03:47 PM
Tha_liks's Avatar
Hope this pic helps
Old May 25, 2011 | 06:41 PM
hbcrazy88's Avatar
i would suggest cutting the harness when it can simply be unplug'ed then plug'ed back in with no effort other than routing the wires were the need to go. like everyone else has said you have 3 harnesses. one for your motor, one for you lights, and the other is your interior harness.
you can go stock or go to rywire and pick up a harness from them..... but you will still need to get the light harness
$MIKE$
Jun 10, 2014 12:47 AM
Asmooh
Apr 23, 2014 04:32 PM
12345678910jdm
Jul 25, 2011 03:01 AM
crxhybrid1320
May 26, 2010 02:28 PM
