Ecu Scanner help
Old 06-02-2004, 01:41 PM
BeesDA6's Avatar
Default Ecu Scanner help
My nephews scanner was reading: P0420 Catalyst System Efficiency Below Threshold. Is that regarding the cat ? the ecu was also throwing a code 67. Thanks in advance
Old 06-03-2004, 03:01 AM
Quitripin's Avatar
Default Re: Ecu Scanner help (BeesDA6)
do you have any other codes for the powertrain? I looked it up and if there is other PO codes (DTC) with a PO137, PO138 or PO141 then you have a related short to the HO2S might want to check and see if you have a short from the lines to the HO2S and also check the HO2S.
Old 06-03-2004, 11:18 AM
BeesDA6's Avatar
Default Re: Ecu Scanner help (Quitripin)
Nope just that one
jochy212
05-15-2008 11:33 AM
civicracer94
12-08-2006 06:22 PM
Thundakat85
04-17-2005 01:04 PM
raene
05-27-2001 12:33 AM
Quick Reply: Ecu Scanner help
