ECU plug question
I had a wire harness made to plug my VAFC directly into my Type R ECU without need for cutting/soldering of the ECU wires. Will these plugs fit into other Integra ECUs?
what year obd is that conversion harness............from the pic, your car must be a 00-01 obd2B integra correct? Not sure what version obd2 the plugs are for (2 gray and 1 blue)...but if you converted to obd2A, you can plug in any 96-99 integra/96-98 civic ecu, if that harness was made to go obd2B-obd2B *kinda pointless*, then you can use any 00-01 integra ecu or 99-01 civici ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">what year obd is that conversion harness............from the pic, your car must be a 00-01 obd2B integra correct? Not sure what version obd2 the plugs are for (2 gray and 1 blue)...but if you converted to obd2A, you can plug in any 96-99 integra/96-98 civic ecu, if that harness was made to go obd2B-obd2B *kinda pointless*, then you can use any 00-01 integra ecu or 99-01 civici ecu. </TD></TR></TABLE>
sorry, good question. the harness was made for a 2001 type R; i didn't make the harness myself. it was made for a stock 01 R ECU so i don't know that it would be converted to anything beyond that.
dwarfsinhondas
Engine Management and Tuning
Apr 14, 2008 04:50 PM
