Are odb2 ecus same plugs as odb1 plugs?
Old Aug 7, 2006 | 05:50 PM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Default Are odb2 ecus same plugs as odb1 plugs?
Is an obd2 ecu suppose to plug into a obd1 harness? or are they different plugs? Because I'm not sure what ecu I have but I remember using one of my friends ecu which was odb1 and it plugged right in and started up and everything.
SORRY ABOUT THE TITLE I KNOW IT SAYS "ODB", thats a typo, i just went to a concert with wu tang thats why
Old Aug 7, 2006 | 06:25 PM
ReDHaTcHyGuy's Avatar
Default Re: Are odb2 ecus same plugs as odb1 plugs? (candy eg)
there different
Old Aug 7, 2006 | 07:53 PM
candy eg's Avatar
Default Re: Are odb2 ecus same plugs as odb1 plugs? (ReDHaTcHyGuy)
cool thanks, guess that means my ecu is an obd1 one.
Old Aug 7, 2006 | 08:12 PM
candy eg's Avatar
some more replies before i order this custom chip off phearable.net?
Old Aug 7, 2006 | 09:40 PM
98vtec's Avatar
moderator emeritus
it will not plug into an OBDI harness.
Old Aug 9, 2006 | 07:59 AM
candy eg's Avatar
does that man i just need 28 pin chip, and i can plug it right in? or do i need the diy socketing kit also?
Old Aug 9, 2006 | 08:07 AM
unknown0001's Avatar
Default Re: (candy eg)
if you have an obd 2 car and obd 1 ecu, why not get the conversion harness?
that would allow you to run the obd 1 ecu on your obd 2 car
Old Aug 9, 2006 | 09:33 AM
candy eg's Avatar
Default Re: (Mr.RHTuner)
i think my i have conversion harness in place that i didn't know about or my engine harness is outta whack and lets me use an obd1 ecu becuase i do remember using a friends obd1 ecu. i just ordered the pherable custom chip.
EnVme
Engine Management and Tuning
Apr 21, 2009 04:24 AM
HATCHingMN
14
Apr 4, 2007 01:33 PM
Hites
Nov 25, 2003 04:41 AM
hondaZvic
Jul 7, 2002 06:37 PM
